  • Replies 234
Posted Images
Ill put it on a disc for you bish
I have to head over to the inner west today - ill leave it in your bucket of bolts :nyaanyaa: - is it still with Nathan?
All good mate, thanks for the offer... but got a mate already burning it for me :)
And no the bucket of bolts is not @ Nathans.... going back on Sat
by all means burn me one steveo. :nyaanyaa:
All done mate.....its sitting here on my desk - come to the Palm Beach cruise? I can give it to you then
Or i could give it to Nick?
Whatevers best for you
Who was it that wrote off the last silvia? :D
Hahahaha.... thats right!!!
And who was the one encouraging me to go flat out through the first kink - as its the only way to make ground with the little silvia as everyone just passes by on the straights...
(Not sure if you were saying go faster or slow down - hard to pick up on what you were signaling from inside the car).
Yeah - some good watching there!
I vote Aaron comes to all trackdays from now on
hahahaha ok
Ill bring the tripod and stuff next time to get some nice chasing action shots.
I were limited to wall huggers because of no press pass to get on track and shakey hand syndrome lol
*hugs tripod :D
haha, i know i was just shouting 'push. push' as you went past each time. fatz was just giggling and trying to see how much of the exhust was left. lol
nice vid aaron. is there any more footage that was edited? If so could you maybe burn it for me? Obivously keen on anything of either spencer or myself driving the alfa :D
    • A bit of data is always good, beats the Facebook experts with their opinions I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
    • Correct And whatever you do, don't use an oil pump gear, especially the one that starts with the same letter as Santa and the last letter ends with the same first letter as Lagoon. Get a proper oil pump, like a Nitto, Tomei, etc. and make sure you invest in a big fk off sump. Won't go into too much detail, but I am sure it caused my previous built motor to go bang.
