  • Replies 234
Posted Images
Wink: Yes
Richard: I've learn from the past to not take a half assed car onto the track, it only results in broken bits. I still need to get:
Braided brake lines
Decent pads
Semi-slick tyres
Splitfire Coils
Catch Can
Sump Baffles
..atleast before you will see me on a track.
Edited by benm
Wink: Yes
Braided brake lines
Decent pads
Semi-slick tyres
Splitfire Coils
Catch Can
Sump Baffles
deadset you dont need any of that sh1t. dont get me wrong it's all nice to have but for someone that loves motorsport (and i know you do) dont let the track days pass you by!
the only thing on that list i reckon is really neccesary is decent pads. under $400 will get you a full front and rear set.
sump baffles is a concern but man it will cost you prob around $1K just in labour to fit them. I've got a set of tomei ones in my bedroom and so far they have controlled my oil surge very well from there. People say, do you have sump baffles, i answer 'yes'. problem solved :D
Top Day first Aaron McGill day I have done and tops fun the littel race at end of the day. Nathan from Grey Imports is a good driver and was hardest by far to past as he made his car very wide. Hope to hook up with Aaron M for future days.
PS Always check brake pads prior to the day.
Yeah i was a bit worried in the last race about your 300 catching up to me.... luckily it was only a 8 lap race and i had a HUGE headstart.
Afterwards Nathan said he did a good job of keeping his car as wide as possible for you John :D
oooooooooooook vid is here
very basic recording with completely seteady shost of the straight 4th corner and a few other bits but i think most cars are on there towards the end of the day
quality is pretty good
http://rapidshare.de/files/21858485/Oran_P...-05-06.wmv.html
i made it this way so its good for editing
WTF!!?? I can access it saying denied P2P....AAARGGGHHHHH
Ill put it on a disc for you bish
I have to head over to the inner west today - ill leave it in your bucket of bolts :mellow: - is it still with Nathan?
problems with power out of the right handers is most likely fuel surge (did you have less that 1/2 tank?). it's quite common. the only easy fix is put more fuel in the tank!
Yeah .. when i came back from lunch after the top up it stopped. But when the tank went to half it came back again..
So is there anything i could do other than top up fuel??
well the only proper way to fix it is with a surge tank (really anti-surge lol). Basically you can run your standard pump feeding the surge tank, with a new high flow pump taking it's feed from the bottom of the surge tank.
Woah that was a quick reply .. haha.
Think i will just stick to topping up the fuel. The surge tank sounds exp.
Anyway, tks
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
