i purchased an el 02 sensor thinking this was the right one for the rb20det but after further research i belive this is only good for the r33's. i went to repco and they dont know the part number for any replacement so i need help with a part number of any brand of sensor that would be suitable and not cost an arm and a leg.
thanks
https://www.sau.com.au/forums/topic/115656-o2-sensor-for-rb20det-r32/
Somebody please post up how to test the o2 sensor as I have narrowed my engines problems down to this or a couple of things.
Do you test it by driving with it unpluged? multimeter?
please help I can not afford mechanic after the cost of my engine replacement!
Don't be fooled into believing that parts for our imported nissan's are hard to come by because they are not! Seriously if u need a new O2 sensor go to Main North Nissan and into the parts area and ask. They will have everything u need and if not they can get it for you.
GoodLuck
yeh, im sort of in same boat as ross80. I thought getting 320 k's of a full tank was pretty standard but people saying otherwise so. Was just wondering where abouts the O2 sensor was exactly. I heard you can test it with a multimeter, but i have no idea where to find it.
Its in a rb20det 1989 gts-t type M
thx :O
ok this is what i read on how to test the 02 sensor.
on the sensor there are 3 wires, the center one is the one that talks to the ecu the other 2 are just to help heat it up faster. warm the car up with a 10-15min drive then while the car is still hot idle the car at about 2000rmp and put the multimeter on the center wire testing for volts. if it is working correctly it should jump between .3 and .7 volts. it jumps about as the car runs ritch then lean so dont expect a stable reading. it may go higer and lowwer by a bit but around that reading its doing its job.
oh yeah use a digital multimeter for best results.
too easy.
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 馃槢
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....馃槳 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will馃ぃ馃馃お馃ぃ
