i purchased an el 02 sensor thinking this was the right one for the rb20det but after further research i belive this is only good for the r33's. i went to repco and they dont know the part number for any replacement so i need help with a part number of any brand of sensor that would be suitable and not cost an arm and a leg.
thanks
https://www.sau.com.au/forums/topic/115656-o2-sensor-for-rb20det-r32/
Somebody please post up how to test the o2 sensor as I have narrowed my engines problems down to this or a couple of things.
Do you test it by driving with it unpluged? multimeter?
please help I can not afford mechanic after the cost of my engine replacement!
Don't be fooled into believing that parts for our imported nissan's are hard to come by because they are not! Seriously if u need a new O2 sensor go to Main North Nissan and into the parts area and ask. They will have everything u need and if not they can get it for you.
GoodLuck
yeh, im sort of in same boat as ross80. I thought getting 320 k's of a full tank was pretty standard but people saying otherwise so. Was just wondering where abouts the O2 sensor was exactly. I heard you can test it with a multimeter, but i have no idea where to find it.
Its in a rb20det 1989 gts-t type M
thx :O
ok this is what i read on how to test the 02 sensor.
on the sensor there are 3 wires, the center one is the one that talks to the ecu the other 2 are just to help heat it up faster. warm the car up with a 10-15min drive then while the car is still hot idle the car at about 2000rmp and put the multimeter on the center wire testing for volts. if it is working correctly it should jump between .3 and .7 volts. it jumps about as the car runs ritch then lean so dont expect a stable reading. it may go higer and lowwer by a bit but around that reading its doing its job.
oh yeah use a digital multimeter for best results.
too easy.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
