Does anyone know how to remove the series 2 R33 airbag wheel? I only need to remove it to put it on straight. I would normally just get a wheel alignment place to do it along with an alignment, but it steers very straight and I have crap tyres so if it's out of alignment I will use that as a method to wear them out quicker :( So far I have discovered 2 large security style star bolts under 2 small plastic covers, do these hold the horn button on or are there other bolts behind the steering cowl or elsewhere? If I need to remove the 2 security bolts, where would I buy the socket for it?
https://www.sau.com.au/forums/topic/115714-steering-wheel-removal/
They are torqs bolts ( number 50 from memmory), any auto shop will sell them, you have to undo then in order to remove the airbag then you will see thenut you have to undo , you may need a gear puller to remove the wheel .
Make sure you buy the "tamper proof" torx driver (ie it has a recess in the centre corresponding to the pin on the bolt head). Should be about $20 for a set of 3 as I recall.
Are there any special tricks to remove the airbag and replace it other than the security screw?
For example, I think I would want to disconnect the battery for at least one minute first and unplug that little plug I can see that goes into the yellow wire. Iโ€™m also guessing that I do not want to start the car whilst the airbag is disconnected as I donโ€™t want the car to go into a โ€˜limp homeโ€™ mode or something similar. I understand newer Fords will emit a warning beep sequence for the next 250 starts if you ever do that!
I can only speak for the R33 GTR's airbag wheel, because that's the only one I've done. But there was no issue driving the car with the airbag removed. I had to do this because once I had the airbag out, I realised I couldn't find my steering wheel puller and so had to drive to my local spare parts shop to get another one.
Oh yeah, something I should add. Once you remove the airbag there are 4 more security torx bolts which are 2 sizes smaller than the size 50 one used to remove the side bolts. I can't for the life of me remember what it was though, I think the mounting for the horn? I'm pretty sure you need to remove them to get to the steering column and threaded puller holes. I remember disassembling the horn to re-tension the springs a bit so now it doesn't rattle, but I forget the details because it was all so straightforward. I'm now glad that the shop only had the kit available and not a single size 50, because it would have meant an extra trip to the parts shop.
ummm if you remove the steering wheel and dont put it back on straight i think that will cause some shit with your HICAS..... that was one thing i was always worried about when removing mine, putting it back on straight. Maybe i'm wrong though :D
Don't be a tight ass, go get an alignment - alignments aren't just for steering wheels going straight, theres other stuff to it as well :D
Yes it will cause some shit with the HICAS if the wheel isn't straight, and now it steers better since I put it back on straight :woot: Before it seemed to be a bit weird before because the HICAS would do something different depending on which direction I was steering. It wasn't too bad before but it's definitely better now. The alignment is good enough for now, I will get an alignment when I replace the tyres.
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc. ย  It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things. ย  Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing" ย  As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things. ย  It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first. ย  There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one. ย  However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long timeย  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingieย  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like ย
ร—
ร—
