IM AFTER SOME BRIGHT BLUE HEADLIGHT GLOBES FOR MY R32 GTST.
AS MINE ARE SHOCKING THEY GIVE OUT NO LIGHT CAN ONLY SEE ABOUT 2 METRES IN FRONT OF CAR.
IF YOU HAVE ANY OR CAN RECOMMEND SOME GOOD ONES YOUVE USED LET ME KNOW.
IAM NOT AFTER HID KITS OR ANYTHING
https://www.sau.com.au/forums/topic/115820-blue-headlight-globes-for-r32-gtst/
THe blue will give you worse vision, it actually removes light from the spectrum to give you that blue look... thats the definition of rice - a mod that makes something worse...
If you really want them still - look for globes with a high heat rating like 8000-10000k will give you a blue look...
RICE?MATE I DONT CARE I COULD STRAP A COUPLE OF THOSE CRAPPY BIRTHDAY CAKE CANDLES TO THE FRONT OF MY CAR AND GET BETTER VISION THAN IAM FROM EXISTING GLOBES.THANKS FOR ADVICE THOUGH ILL KEEP THAT IN MIND:)
All i was saying is that blue gives less light than normal bulbs... you're complaining about lack of light ...
Anyways did you check with the JDMImport guy?
here i found the link, he has them
http://www.skylinesaustralia.com/forums/in...howtopic=101562
I've got ( and am using ) a pair of H3C globes by Raybrig. They are around 80W ( instead of the normal 55W ) and are the best I've seen short of HID. They have a slight blue look about them from an angle but are clean white light projected out the front. I'll try to remember to get all the details for you tonight. Can't recommend them highly enough :P
I'm sure I've seen someone on this forum that deals in Raybrig.........
Here's the globes I was talking about. If someone would like to translate it all into english it might make some sense :)
Anyway, these are the best globes I've used. If you find someone on this forum who deals in Raybrig it might be a good idea to approach them about a group buy. I'll be in if the price is right :O
there is a trader(osaka boy?) on here that sells them - pricey though... if you are after better night vision then may as well shell out for a hid kit - should be sellers/trader even gb on here for some or you could always try ebay
I think you're refering to chiba_osaka_boy but he doesn't deal in Raybrig, he deals in Polarg ( or something like that ).
Anyway, aren't HID kit's illegal ?? I have no idea why they would be but I've heard they are. Please correct me if I'm wrong. :laugh:
Anyway, aren't HID kit's illegal ?? I have no idea why they would be but I've heard they are. Please correct me if I'm wrong. :D
Far as I know blue is ilegal and You need to be adjustable high from driver place.
I got them on car and can see shit.I going to trow them in bin.
As far as I know, no hedlights are adjustable in car ( skyline ).
Throw what in bin ? HID ? Raybrig's ?
THANKS FOR REPLIES FAT 32 YOUVE BEEN MOST HELPFUL
TO OTHERS SUGGESTING I GET PHILLIPS AND H4S AND STUFF I CANT MY HEADLIGHTS ONLY ACCOMODATE H3CS AND SAME WITH WIRING OBVIOUSLY.PHLLIPS DONT MAKE THEM FOR MINE
BUT IVE NOW SOLD CAR SO NO NEED ANYMORE THANKS AGAIN FAT32:)
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
