Guest insane
I dont really have time to read 11 pages of threads so im sorry if this has been said before....
I am a northy and i know of a few roads out the back of wanneroo/pinjarra that are not speed restricted and also fairly curvey. Its also pitch black out there at night which could make things pretty interesting.
Anyway if not this cruise, maybe a future one...
Insane - if you have any ideas feel free to PM either me or dan the man - as we are the club events co-ordinators.
Even though those roads are not speed restricted - you legally are not meant to go over 110km/h. Our aim is to organise safe cruises and promote people to drive with in their limits. A curvy "high speed" road in pitch black doesnt strike me as the safest thing to do - but it sounds great for one of our day cruises which we usually finish with a BBQ!
hi guys just wondering how can i join the cruise or skylines australia im in perth is there anyone i should speak too or just show up at cruises. :(
welcome to just turn up but please introduce yourself to US WA EXEC COMMITTEE
cheers
Joe
ohh yeah welcome to the SAUWA forum.
edited by Dan
Joe u know why :D
Maybe we could do a "show off" day kinda thing, get all of us together down at the Esplanade and we can show off the cars, stick up a big skylines Australia WA banner and get some more members, give ppl a chance to ask questions, do a bit a publicity and have a BBQ and play some games on the grass!
maybe do it a Langley park or some where were u can park a lot of cars and lots of ppl will see
was jsut some thing that poped into my head
  • 3 months later...
  • 4 months later...
cheers Matt .... im sure someone will give you a ride on a cruise. For random posts etc check out Whoretown ..... its where we just informally chat throughout the day.
:D
Niz
hey i was just thinking about your cruises.
i dont know how they work, but maybe we could try do like a chrissy cruise or a
"christmas eve's eve" cruise, maybe just a 1day or something,
like what gts4_fun said, maybe a show-off during the day and then a cruise to go see teh chrissy lights or something.
i dont know, it's just a suggestion.
Thanks for the suggestion Matt. It takes a bit of work to organise a cruise and everyone is really busy leading up to christmas - including us Event's Co ordinators! ;) Plus I dont think people walking around with kids looking at the lights would appreciate us in loud cars cruising past. :cheers:
But we are planning an SAUWA day cruise in January, so keep an eye out in the events section for details. :)
From Liz and Dan
SAUWA Events Co-ordinators
Yeah I've driven one before... There's absolutely mad cars.. And easy cars to pull a bit of extra power out of them as well. Pretty much a beefed up Ford BA XR6 Turbo. There rated at 270kw i think? They basically look like a falcon GT without the power-bulge bonnet and only come as 6 speeds. Oh yeah and they produce 560nm (the most of any australian production car ever built) at 2500 rpm.
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
