How about hide and seek, game between the two teams of cars.
We get 15 to 25 cars on each team and have a co driver with a phone number to check wih the coordinators to track the cars and locations. Each car can move the hiding position only twice.
While the other cars go hunting.
We select an undisclosed area with just enough streets and hiding places. Enough for cars to seek each other. Something like corner of Round house freo. Or a light industrial area somewhere......
And we make the time limit for the other team to round up all competing cars.
The winning team gets the drinks from the other team ...or a general prize......
Just a thought guys and gals :)
al
  • 3 weeks later...
  • 3 weeks later...
Ok, posts for cruises are few & far between on here, but...................
any idea when the next sauwa cruise will be??????
Will have my car in the next couple of weeks & will deffo go to the next one (even if it is a while away), but even any other open cruises for meeting people, checking out their cars etc etc.
Cheers.
Joe - we plan to have one official SAUWA cruise a month.. alternating bewteen a sunday/bbq one and a night city one.... if you came to the meeting mr joe joe.... hahaha
hrm a monthly cruise would be great perhaps on monday nights :( at least is something to look foward to when the weekends over and back to work ;)
We have our night cruises on friday nights because we can run them later with less traffic and the day cruises are on sundays with BBQs
You guys are free to organise and advertise your own cruises on here if you want to run one on a monday night! :rant:
ahh i see :D bad news for me unless you run the friday night ones after 11:00 Pm ish and sunday day ones before 2pm haha
tis the only think that sucks about cooking industry working 6 days a week except monday night :(
ohwell
ok, so sauwa club cruises are once a month? which friday do you guys hold it? trying to find if you guys do a monthly cruise like silviawa.
We dont have a particular friday - its just when Dan has time to make one or there arent other events on
Seriously - feel free to organise your own cruise and advertise it. Read the cruise rules and guidlines for making a cruise. People will come!
  • 3 months later...
  • 4 weeks later...
You can start a new thread dude.
No point ending this one when its called "Ideas for our next cruise"
*Throws an idea up in the air..
How about every second Sunday we head down to the rivervale sunday session. "its not a cruise" but its an event and its on every sunday arvo, will get some people outa the computer room! + people can meet face to face.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
