R33/34 Gtr And Gts-t Parts
Weird the Gktech one doesn't have the 3 holes and is only a 5min install if you have the standard front bar.
Honestly, as someone on the standard PS4 controller, should be relatively easy to get gold. Remember you have more grip than you think.
Fitted some Advan AD09s to try next. Likely slower than the CR-S but should work in the wet and last longer. Off for alignment and the new plates worked a treat! I was finally able to hit both my drift and grip alignment targets with the same setup! Grip Front: Toe total -2mm(1mm out each side) Caster +7° Camber -3.8° Ackerman +15° Rear: Total toe +3mm (1.5mm in each side) Camber -1.5° —————————————- Drift as above but drop the front sway bar and change the below. Front: Toe total -10mm(5mm out each side) Ackerman +5°
@Duncan can you put the Link in, and measure all the power input voltages with a multimeter. Specifically looking for one that is low. Then put the other ECU in that it runs on, and measure those voltages again with a multimeter? If all of your voltages read normal on both ECUs, but the link is still reading low internally, your issue IS the LINK. If the voltages drop low on the multimeter while the Link is plugged in, but not other ECU, then the issue COULD be wiring in the car, or it COULD be the ECU. To rule out wiring, work out how with an ECU removed, you can trigger all the necessary relays, and then measure resistance from the pin that is reading low at the ECU, to the batteries positive power. I have a sneaking suspicion your issue is the link, it's not reading the voltage properly, possibly a dry joint, or a Cap dieing, and because voltage is low, it's likely attempting to compensate on fuelling and the engine won't run.
By DraftySquash · Posted
Hi there, Does anyone here have the carbonetics slam panel installed on their R34 GTT? Or used to have one and got some pics of how it sat? https://carbonetics.net/products/1999-2002-nissan-skyline-r34-gtt-cooling-slam-panel?srsltid=AfmBOoo6Uz0nuxGI3qC0sn56KJI6PMgh0OvV-pbegsPDHTtTxz4IMljc I’m just trying to get an idea of how they sit once installed but these guys have no pics. biggest question I’m trying to figure out is what the hell the 3 holes at the front of the panel are 😂 and where they bolt Thanks in advance
