WGMG is Mario Kart on Nintendo DS. Why is that if the computer players ram me i get speared off the track, but when i ram them, i get speared off the track!!! Makes no friggin sense!!!!! And also, why is the only weapon i ever get those crap banannas while the others get rockets and bombs and stuff. I call shenanigans on this game!!!
Nintendo, you suck!
Rant over :)
I feel your pain. Don't get me started. When you need anything but a banana cos the guy infront is all lined up....guess what...you get about 5 bananas in a row. Bullsh*t
WGMG when cops follow you. every time you change lane or turn they follow, and especially when there driving the oppisite direction and they do a Uturn just to follow you even when you have done nothing wrong, even one time followed me too my house and pulled me over as i pulled into my driveway so that all my neighbours could come outside and watch
WGMG is when someone copies your "line"!!
Gavin, the hug line is mine, proof is in the quote above...youll hear from my lawyers :)
brad ive spoken with your lawyers and sugest next time you fork out for someone a little more experienced
turns out your paperwork was out of order and i am now the proud copywrite holder of the lines
"someone needs a hug"
"woosa"
and
"eat my shorts"
so eat my shorts buddy
"woosa"
and
"eat my shorts"
And the only word there that matters . . . COPYWRITE. . . looks like you lost your line brad . .
Gavin, maybe you could charge brad to use YOUR line . . . just an idea
what grinds gavs gears today
sitting down to enjoy a couple of episodes of my new anime dvds only to find there are NO DVDS in the cases of the full set damn it
nasty email time me thinks
going on a cruise friday night and getting home at 2:30 saturday morning. THEN waking up at 5am to go to work for overtime on saturday.. for 9 hours.
im so buggered and its australia day tonight.
what am i going to do :ermm:
bubba thats f**kd up-much damage?
front right indicator smashed (nooooooooooooooo! my clear lenses!) and the point of the guard above it is punched in a fair bit, looks like new indicators and a new guard and she'll be right :glare: not as bad as it could have been!
and brynj, that also sucks! I'm just lucky it wasn't some random in a carpark that did it..
Edited by bubba
You know what really grinds my gears, you Skyline Australia.....F*** YOU.
Nah I joke I joke. I love SAU.
Anyway, you know what really grind my gears? Well of course when someone doesn't use the clutch. There goes you gears!
cant you tell them to get the fack off ur property, or do we have no rights anymore
WGMG seeing an black xr6 turbo that is absolutely tea-baggin the ground because of how low it is, then looking in side the tinted windows to see two cops and cop lights on the front windscreen :)
would be a bit stupid of them to give a yellow sticker to someone for beeing too low :ermm:
should have given a bit of BOV and a rev, and urge them on
then when they pull you over for 'hoonin' do a citizens arrest on them for havin a 'hoon' car themselves.....
when people assume your a v8 hater coz you own a skyline!
f&^* i was bought up a v8 boy, creaming over corvette's, camaro's, hsv's and all that
i mean, i have a chevrolet badge for a belt. its like its a crime to love all types of cars
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
