Trolling/abuse
QUOTE (SAU (WA) WASTELAND RULES 2008)
(a) Exercise common sense and be considerate toward your fellow users. Diversity of opinion and intelligent civil discourse is encouraged; by the same token, insults and “flaming” are not tolerated. Disagreeing with an idea of another community member is different from attacking that individual.
Truck drivers who are so ignorant they dont stop at stop signs and decide to cut me off while im doing 80kph. And then has the courage to hang his bogan arm out the window and hound me for his mistake. Not much needs to be said other than complete douchebag!
wgmg :)
my brother
my brother saying if you had abrain when he has trouble reading
the learners permit age
that nothing is cheap [$3 for a can of coke at a servo]
that ill own nothing because of bligh
that i live on 2 acres and my dad wont by me a car
my mum's nonability to drive in a straight line backwards
EDIT: gt5 being late
wat doesn't :)
5 in a row for state of origin
natural sellection
Edited by sleeperdatto
moderated threads for selling =x
i know sometimes people post silly things...but threads dont get updated unless a mod is online.
Car for sale threads get updated within 30 mins on weekdays.
Weekends and nights it takes a little longer.
We're testing a few different alternatives in the parts section so it may be a little behind right now.
We don't put these systems in place for our own entertainment, they are to benefit the forum/forum users. So we appreciate your patience :P
spending a good hour mounting the office media server on new server rack mounts, adjusting the size of them so they fit in the rack in my office rather than the server room, go to turn it on and having the fan louder than a a380 loosing an engine....
EVERY THING :)
nah but what really grinds my gears is popo that hide speed cameras behind parked cars
the emergency department at RPH
ppl that go to emergency with blood noses and splinters, im not kidding
the fact morphine does nothing 4 kidney stones but thats all they give u. f**k give me a tranquilizer. next time im just going to take nurofen plus and tramadol and get a high as a kite
and not forgetting youtube adds for good Charlotte and short stack brrr
  • 4 weeks later...
  • 5 weeks later...
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
