when u let people out in traffic and they dont wave to say thanx
those bitches
And that my friend...
Wins you the!!
That Really Grinds My Gears Grumbler of the Week Trophy!
Tigeryas gets second place with his grumble about the price of Coke.
:D
when your in a merging lane and the person behind hell plants their foot to get infront of you when clearly its just not going to happen and then they hell tailgate ya!!
who does that :D
you know what else grinds my gears, sitting at work, inside, when its actually a sunny day....doesnt help if you have a window seat either....could be out driving or doing something,......but work.....:D
Guys with Small Man Sydrome that sit there and then remember that they have a penis the size of a door knob from the Barbie Dream House, so they belittle the nearest person to make themselves feel 'bigger'. YOU MY FRIEND - ARE A C*NT!
Guys with Small Man Sydrome that sit there and then remember what a small dick they have, so they belittle the nearest person to make themselves feel 'bigger'. YOU MY FRIEND - ARE A C*NT!
:D totally agree
i just hate bogans who think there is actual value in trying to steal a 16 year old car..whats wrong with ur vls or whateva shit..not good enough is it...... :)
Try and steal your car hey? Dirty little buggers...
yup!! left me with a small fix bill..small price to pay i guess since i still do have my wheels thank God, but what annoys me is Burswood. In oreintation they told us to park in staff parking cos its safer and they will cover on some part if car got damaged or things got stolen. now that its realy happened i get told..sorry tough bikkies we aint liable....
Going out to the pub and getting trashed one night.. then going out the next night and getting bugga all sleep then finally passing at at arounddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddd
dddddddddddddddddddddddddddddddddd.......
what grinds my gears?
not getting trashed and posting while still off my face
i did do the jacob's ladder twice then running to the bell tower and back with a mate at midnight though, then going to hungry spot for a bacon and egg burger and chips...
and what also grinds my gears? burgers that aint decent enough
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
