ah nice nice..
what kit?
i might contribute to this thread while im here..
what grinds my gears - removing more skin than engine parts whilst attempting to do my engine swap!
What happened to the days of people driving imports acknowledging each other with just a thumbs up or something ..... people are getting way too snobby haha. When i had my Z31 every second silvia i went past waved and on the odd occasion a skyline driver would wave.
That never happens anymore..... theres just no love.
I get the same, I only wave/thumbs up to other skylines but I'm yet to find out to do it back :O The only contact I get with others are the ones that pull up quickly alongside you, but then dont look over. ;) The same after a run with someone, people that lose never seem to give a thumbs up.....
I did get a thumbs up from a 99 xr6 & his passenger though haha
Hahaha just came in here to say the same...
I do admit though I'm a little embarrassed but I always look over at them or spy them in revision mirrors with a smile and even though I was full of dots on Monday (hahah) they could of smiled back :( lol
What also grinds my gears are computers that decide to blow a fuse when there is nothing open on a long weekend GRRR!! and your stuck at home sick :laugh:
What shits me is when I come home and find my letter box all caved in and my welcome sign on my gate smashed up in bits... have a strong feeling i know who it is seeing as i saw his car drive past my house a couple times... when he clearly has no need to be in my area - I live in whoop whoop... oooooooh revenge is so sweet - especially when they drive 70K cars ... payback's a bitch :)
AGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
gears are to ground to even express in type
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
