Alot like how only one of your air conditioning functions works :)
only because i accidently pulled it out trying to get heat on while i was driving on a bumpy rd in busselton hmmm
WGMG? Bunbury roads, they are shite!
WRGMG: Public transport, when people in front of you walk hell slow down the stairs and your train is about to leave.
also to a larger extent, the Australian Government a bunch of dickheaded thieves
taxi drivers who stop on busy roads when there is a perfectly good side street or driveway,
taxi drivers who are pulled over in a fkn stupid spot then when its clear to overtake they pull out into u.. then they do 15k's under the speed limit so u overtake them and they swerve at u on ur way past.
taxi drivers in general,
is it me or everyones washer jets seem to have problems?
mine just stopped working and i cant work out why :down:
WGMG are tossa's who pull into the gap you leave between yourself and the car in front..... and to the tossa in the 32, that gap was not for you dickhead!!
I really hate this, especially when youre going down the freeway and ESPECIALLY when its raining.
WGMG, stupid mums in 4WDs late picking up their kids and haaave to floor it to get 1 car infront when lanes merge! :blink:
merges are just overall shite here.
i saw someone get to a merge on leach hwy the other night, and they braked...there werent even any cars around them...(i was behind)
but yeah
crazy people in over sized cars that werent even built for the city :blink:
eff off.
Engineer's who come from another country, can't speak the language and have no experience in the job. Then when they find something that they think isnt right but is then give you a tune about it. Grrr! :D
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
