Hey people,
Have got for sale:
1 * BOSCH Genuine 040 Pump => good for up to 370HP $220
1 * BOSCH Genuine 044 Pump => good for up to 700HP $240
Both are brand new in unopened plastic, bought them a while ago, didn't use them, they are no longer needed.
Also,
1 * Unbranded Bosch Equivalent 040 Pump => $180
This is effectively a 040 pump, but without the Bosch stamp. Manufactured in the same factory, EXACTLY the same as Genuine Bosch. Assured quality without the higher cost.
Will post anywhere, at buyers expense. May deliver in Eastern Suburbs if needed.
PM or call for quicker response
Thanks,
Mat.
0400 558 030
Bosch 044
Bosch 040
Unbranded 040
Edited by femno
am i reading it rite u want $250 for the BOSCH 040? have a look in the business section mate these got for $235 at my door step..
tis only 15 dollars n postage is a couple more.
Ill give you $200 for the 044 and ill pay postage let me know.
Sorry mate 250 is already cheap. Thats the best i can do. You wont find one anywhere else for that price.
have u got any 044's left. these will suit r33 wont they?
dumb question, just making sure.
is the o44 straight fit into the r32 gtst?
To an extent. The 044 can be fitted into the tank no probs, the cradle requires minimal modification, and you will need two fittings for the pump, one for either end; and because the 044 is an external pump, you will also need a sock for the IN side of the pump to allow you to fit it internally.
Hope im not too confusing, you should probably have it fitted by your mechanic.
PM me.
Mat.
Whereabouts in Melbourne are u located?
Cause im in urgent need of a fuel pump for my R32 Gtst..
Thanks Thalia ;)
Guest
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
