hi all,
i just purchased my r33 gtst 2 weeks ago, n noticed a small oil leak on the floor, became bigger everytime i drove it and had a look at the prob 2nite..
there was 4lts excess oil put into the motor that i drained out, the car does run smooth and fine, with no misses, but does drink a fair bit of feul (60bucks to fill and only 280km's? grandma driving).
i cleaned out all the piping from the cooler to t/b, but didnt get to to the other side.... i then took it for a test drive to come back and find it dripping again, coming out of 1 of the welds on the cooler piping that goes to the t/body.
car has done roughly 100,000km's, and will get compression tested on saturday
could this be blow by? or just the car having 4litres excess of oil?
mods are gtr cooler, zorst, pod, feul pump(unknown but big), stock boost
please help asap, as i still hava 3month warrenty
https://www.sau.com.au/forums/topic/115960-oil-in-cooler-pipes/
firstly i'd replace that pipe with the dodgy welding.
it could be blow by.. best way to tell would be to get a catch can properly installed.
the compression test will tell you alot though.
it could also be a blown oil seal on your turbo.
I agree with a possible turbo oil-leak. There will always be a little bit of oil coating the intake pipes, and depending on how much blow-by you have coming back, it could build up like that.
The fuel economy might be something else, but you should really get that weld looked at, as Security said.
4 litres of EXTRA oil? Wow, thats alot! That much excess oil is certain to cause the extra buildup of oil in the inlet tract due to an increase in crankcase pressure and would for sure be dipping the crank, so that may go someway to your terrible fuel consumption (dragging the crank through oil causes massive drag and oil mist on/in the engine).
But yeah, you need for repair the dodgy weld, and while your there spray a heap of carby cleaner through the inlet system to get rid of the oil, otherwise you might find yourself forever re-clamping blown-off 'cooler pipes.
thanx marlin,
any other reasons it consuming so much fuel? my mates get bout 400-450 kms from their r33's, me only 280kms :P
also the car is spluttering once it hits FULL boost?? i regapped my spark plugs to 1.1, but i might put em down to .8?
Edited by Mark-R33
The fuel economy could be the O2 sensor. If at all possible, beg/borrow/steal a consult cable and see how the motor runs. The O2 sensor readout should oscillate with the lowest amplitude less than 0.4V and the highest amplitude greater than 0.55V. It should oscillate with a min frequency of 0.8Hz.
If the sensor isn't doing this, according to Nissan, it is stuffed and should be replaced.
Then again, if you have a bigass fuel pump, 280km/tank may be normal?
thanx for the help, managed to fix the car, and if ne1 has the same problem this might be a fix:
regapped plugs back to .8, and put tape around coil pak (like in the other thread), this got rid of the splutter on boost
the oil problem was due to the fact that the dikhad put 2much oil in, hopefully its all good
a compression check was also completed, the results are:
C1 C2 C3 C4 C5 C6
160 162 161 160 164 162
im guessing this is good coz they r fairly similar????
Edited by Mark-R33
yep. good even, high compression.
you'll find that the tape only works for a few days/weeks maybe.
clean out the inside of your coils with a dremil drill (very lightly!!) just to get the build-up of crap off the inside of them.. or you can try steel wool.
    • Hard line it, you will be thankful later on, if you car had hicas, use that as your return.
    • Hydro lifters not bleed up could be the ticking noise
    • You know the worst thing about acquiring more space for me? I tend to acquire more things to fill the space...
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
