Based on what I have read, I think it looks like a viable alternative to a GCG hi-flow. As long as the oil lines etc are done properly, hopefully shouldn't have any problems.
Slide: I will put my order in shortly mate.
  • Replies 264
Posted Images
For those who still want a near complete bolt up turbo we have been doing Highflows with a Vtrim wheel and a new Garrett .60 a/r Compressor housing.
The exhaust, manifold, oil and water lines all still bolt up the same with just a silicon elbow being required to meet up with the stock cooler piping.
We have been using these as we can fit even larger compressor wheels inside them.
We can also get Garrett housings with an a/r of .72 and .84 aswell and can create any combination Hybrid.
Picture of the .60 a/r housing with comp wheel.
They do cost extra and to find out a cost simply ask with the combination you had in mind :D
Guys i also want to encourage you to put up your power figures with the turbo's i have sold up.
If you could find yours SkylineSII that would be great
We are also now working on a plating system to label the details of the turbo on its own plaque which we can convert as its becoming hard to keep track of the parts used in Hybrid's but soon will all be listed on the turbo not just in our books.
:D Aaron
Still Journal bearing Ben
For that particular setup with the same VG30 rear highflow it is $1090 delivered
Mainly because of the housing and backing plate costs.
It will function similar to the straight VG30 highflow but will have a bit more headroom up top.
Boost is 19-20 psi max.
:D Aaron
Sorry guys, but this has just turning into a pricing and quoting thread.
I think both sides have said thier bit, take it to the For Sale section or Aarons website for orders.
cheers
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
