  • Replies 264
Posted Images
So Dan,
this SlidingPerformance Roller-bearing turbo spools slower than the stock ball-bearing turbo? You notice this difference?
doesn't any turbo with a larger rear AR ????
just a question dan
did you get the exact turbo off the shelf to what the site shows or did you get it customized some how?
why do you reach 10psi at 3,000 rev?
I thought you would be reaching it earlier because apparently Satanic reaches 11psi at about 1,800 revs. His turbo is customized though.
maybe you will need to tune your ecu?
My one isn't the 'off the shelf version' it has a larger exhaust side. Yes it is noticeable that it spools slower than the stock turbo, but when you look at how fragile and light the stock one is; it's no suprise. I'm pretty picky about lag and this turbo isn't bothering me in the slightest, especially when it kicks in :thumbsup: You can't expect stock response out of a turbo which will way surpass the current power output.
I could be reaching more pressure earlier by throwing some timing into the tune and removing some fuel around 2800-3000rpm, but I don't think there is a hope in hell of getting 11psi at 1800...I could only just get that with a stock turbo on my 10:1 compression engine!!!
I think most people out there, even with GCG highflows would be saying the same about where the boost kicks in.
I'm 1000% happy with it :dry:
hmm... Interesting Dan.
I hope mine will perform similar to yours.
Planning to install it next monday.
I'll let you guys know how it goes.
Hopefully its similar to yours Dan.
I also have the bigger exhaust size.
By the way, have you had any chance in dyno differences between the stock turbo towards this turbo?
No haven't had a chance to get it on the Dyno yet, also the turbo will take about 1000kms to run-in...until then you'll probably be boosting around 4000rpm like I was for 2 weeks, once everything had worn in and loosened-up it's awesome.
I have said this many times, so I apologise for repeating myself if you have read it before.
The GCG ball bearing high flow on the R34GTT made more power EVERYWHERE than when it was standard. That’s from idle to redline.
:dry: cheers :thumbsup:
I can't comment on power from idle, I'd assume more considering that the exhaust side is 1.5 times as big as the R34 exhaust housing...hence flowing more, hence more power.
I'd say there could be a slight difference in power with this turbo around the 2800rpm-3000rpm range as my tune had a lot more timing in this area and power peaked very steeply with the stock turbo (poor traction at low rpm)
Once again though I'd be interested to see a pressure log against rpm for the GCG if anyone has this info laying around? Then we'll have something concrete to compare with regard to spooling time (even though shaft speeds aren't available to us)
Currently the car feels a lot more street friendly.
I've actually found this interesting, as the GCG isn't as responsive as the stock turbo, so wouldn't be making pressure at the same rate, how would it have more power in the 2500-3000rpm range?
As mentioned before, I'd understand from idle to 2500rpm purely from the better flow of the exhaust, but this wouldn't account for any extra power in the rev range where the stock turbo is already at a decent shaft speed and the highflow just wouldn't be at the equivalent speed...there must be at least 500rpm where the GCG doesn't make more?
When I say “more power than standard” I mean SHOWROOM STOCK STANDARD. That’s;
Standard dump
Standard engine pipe
Standard cat
Standard exhaust
Standard ECU
Standard tuning
Standard air filter
Standard intercooler
I suspect what you are comparing is all of those things modified, but with the standard turbo. However that is obviously no longer STANDARD.
:( cheers :woot:
Edited by Sydneykid
Standard dump
Standard cat
Standard exhaust
Standard ECU
Standard tuning
Standard air filter
:( cheers :woot:
Ahh OK, you mean extra-shitty standard...yeah I'll go with that, the extra flow in just the housing would be an awesome improvement for a stocker which actually feels quite laggy in factory form.
but the GCG has a bigger compressor so even at lower spool it can create the same airflow.
That's true, but it still doesn't reach a shaft speed which would produce the equivalent pressure before the stock turbo.
Who would that be? SK? or PaulR33? I wouldn't be calling them keyboard mechanics....
The purpose of this post and forum is to promote open discussion and information, from all sides.
I havent heard anyone say that these turbos were shit, all I've heard is people's opinions, own trials and information they've provided, ultimately it is each persons own choice to choice their turbo for their own uses.
If anything I'd say most people have had positive feedback, and that's a good thing.
Ummm no...
I have had quite a few worthwhile discussions with both Gary and Paul, who are both knowledgeable.
I am referring to the sheep...so re-read my post and build a bridge...
Don't turn a good thread into your own self promotion... :(
Dan do you have this turbo in????
I am confused with all this GCG discussion...
????? its quite clear Dan now has this turbo installed, and seems to be happy with it
Yep the turbo is in, and I'm extremely happy with the performance (just to recap, feels faster running 10psi, than the stock turbo running just under the factory retard ~ 12psi)
Thanks Dan!!!
Can't wait to see what it pulss with a decent tune. So what is the pocket damage fo this little upgrade???
What are the specs seeing as this is not an "off th shelf" item???
tangles...thanks for the input...
Guest
    • Oh and my rear arms may need some attention too.
    • Bushings are almost done. Check the date stamp 😂 these are likely the original bushings with 27 years and 243ks on them.     Was too dark to get a pic of the worst one.
    • Porous blocks are a known issue on something like a Porsche M96, it's not really something I've ever heard of on an RB26. It's possible what people thought was a "porous block" was really a cracked block that they just didn't spot the crack on.
    • This is a controversial subject really, the whole power vs fun thing I mean And this is the main reason I got back into a MX5 Of the last few notable daily cars I've owned whilst I have frequented SAU R33 GTS-t: fun, but because I'm a idiot I modified well past a reliable fun car and ended up hating it, although that was my fault because I tried to have a daily cruiser and race car all in one, the family called it the sometimes car, because sometimes it was working, sometimes it was broken, gladly sold it NB MX5: brilliant car, thrashed the Bejebus out of it, but, again, was stupid and deleted the air con, power steering and stripped the interior out, whilst still fun, and reliable, and super cheap on consumables, it was not a fun place to be going on long cruises, I did love it, but basically every family member hated going anywhere in it, sadly sold it 2015 WRX STI: soulless thing that looked like your average Kia sedan and had that horrible boxer engine with glass ringlands, the family did like it though, that thing was one of my stupidest purchases and I still regret it 2017 Toyota 86: 😪 if I didn't crash it, I would probably still have it, it was a fun little thing, even with that horrible boxer engine, the family did like it, the only reason I didn't get another 86, or, BRZ was the boxer engine, I should have learnt after owning the STI, but I'm a idiot VX SS: great cruiser, fits the whole family, and was fast as.....in a straight line, but a big fat thing, so no enjoyment throwing it around corners, the family was unimpressed with the whole boganness of if, but they did admit it was a comfy place to sit on long cruises As for the NC, I feel it is perfect for what I want, or need out of of a car, whether I'm cruising the Hwy, back roads, twisties or peak hour traffic, the Mrs doesn't mind driving it either, or cruising in it as well, although she does bump her head of the roof nearly every time she gets in, which is farking hilarious, and the kids love taking it for a thrash as well So basically, I've had constantly more fun, and way less headache and heartache, both on the track and on the street, in low powered cars,  go figure.....LOL One thing though, the Mrs has stated that the cams have made the exhaust sound much louder, which they have, but it doesn't bother me, in fact, I actually like it, but, to negate any future comments from the Minister for War and Finances I may look at some changes to the rear muffler set-up to drop the volume down a tad to appease her when we are out and about in it
    • You will need to extend the turbo inlet pipe somehow, which could/might be done with silicone/rubber pipe, but might need steelwork, depending on your intake. And you will need to change the pipework on the outlet in teh same way, but this is more likely to need steelwork.
