well as some of you know i'm in the process of putting an XR6 Turbo on my Rb30 Twin cam, most of it has been reasonably staraight forward apart from the actuator was fouling the front compressor housing so i made this little bracket and shortened the travel so that now it doesn't foul anything.
Basically i want to know if anyone can see this being a problem now or sometime in the future? I tested it with compressed air and it opens fine!
One thing i noticed after welding it was that it had a lot more movement in it, due to the heat. Could i have damaged the internals of the actuator? Can anyone see this being a problem?
The other things is that the wastegate flap now only opens to about 45 degrees, could this be a problem?
Edited by mr_rbman
The problem I see is the actuator not working in the same plane as the wastegate lever so the actuator rod deflects and this may not suit its spring and diaphram . I have had one modified but we used a die nut to run a thread along the shaft and screwed an adapter and lock nut onto it .
The actuator on yours is way clear of the compressor cover but closer to the turbine housing and the bracket is bolted to it which is a worry heat wise . Some turbos have the actuator a long way forward and use long rods . I have a pic of a Garrett TB31 (propper factory T3/TO4E) that I'll post up so you can see how they did it .
Back soon cheers A .
I assume your turbo is the Ford XR6 type GT3540R which uses a TO4E .50AR compressor cover similar to this TB31 .
Indexing the covers/housings can make life difficult with integral gate type turbos but usually something can be made to work .
Most brackets I've seem made were 1/8 mild steel plate and if folds were needed they were made in a vise with a hammer . Cardboard templates help out and can be traced to the plate initially complete with holes marked out .
Given a choise I would always mount them off the comp cover to backplate bolt holes .
Cheers A .
thanks for the pics, yes it is an xr6 turbo. I was thinking the plate would act as a heat shield??? (5mm thick) Could i have damged the diaphram by welding the rod? I couldn't mount it off the compressor housing as it fouled wherever i put it given i've put the turbo on the standard manifold!
nah, been there done that, it almost hits the engine mount cause its on the standard manifold! The way its facing is the only way i can have it!
Do you know if you can replace just the internals of your wastegate actuator? I'm just a little worried i damaged it while welding it!
Sorry to be so negative........
1. The wastegate actuator should always work in the same plain as the wastgate opening. Wastegate actuators can tolerate slight changes in angle, but I think you have exceeded "slight".
2. Mounting the wastegate actuator so close to the turbine cover is asking for problems, they don'tlike too much heat. That's why the reliable factory wastegate actuators are mounted off the compressor cover, a long way from the turbine.
3. Welding the wastegate actuator was not a good idea, they are simply a diaphram in a metal case, with lightweight spring. Welding heat can have esily damaged the diaphram itself and/or the spring causing it to lose tension. A new wastegate actuator would be on my list.
I would make a bracket off the compressor cover, as forward as necessary to clear the compressor outlet piping (similar to what A has posted). Then lengthen the wastegate actuator rod to suite. Bolt the wastegate actuator onto that bracket, don't weld it.
:O cheers :ban:
thanks for the input both of you, i've already taken my turbo to a bloke here in SA and bought a new actuator cause i wasn't happy with how i'd set it up for the reasons you'd already stated!
May have cost me a bit more but atleast i'll have peace of mind now!
Good stuff mr_rbman
I can't wait to see how that turbo goes on the RB30 mate.
Let us all know how the setup goes in the end.
Will do, fingers crossed it'll be on the road by the end of the week if nothing else goes wrong.
Anyone else looking at doing an actuator mod, don't mount it off the exhaust housing for the above reasons stated, too much heat for an actuator to handle!
You could always ceramic heat treat it.
:ban:
turboac12ot.th.jpg turboac24dm.th.jpg turboac32vj.th.jpg turboac47hg.th.jpg turboac56aa.th.jpg
Well here's my new oil and water lines with new actuator bracket, much better than the first mod i did! Couple of little thing left to do but should be on the car shortly!
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
