This is the ultimate challenge to see who has the biggest most powerful car: add all the cars that you have owned together to see who has the biggest motor, cylinder and KW output. Here goes:
1.1979 Gemini Coupe 1.6lt 50kw
2.1984 Cordia Turbo 1.8lt 110kw
3.1992 Lancer GSR (non turbo) 1.6lt 90kw
4.1994 GTI Swift Turbo 1.3lt 120kw
5.1992 VP HSV SS 5lt 185kw
6.1988 VL Calais Turbo 3lt 180kw
7.1989 Toyota Corolla 1.6lt 20v 119kw
8.1992 R32 GTS-t 2lt 200kw
Equals = 17.9lt 40 cylinder 1054kw/1412hp Beast
should of bought a truck!!
https://www.sau.com.au/forums/topic/1160-1412-hp-179-litles/
1. Mitsu Scorpian (machine!!) 2.6L astron, no idea of power - prolly ~110kw
2. VC Commodore - 3.3L ~95kw
3. Toyota Hilux Surf - 2.4L ~90kw (just a guess)
4. N13 Pulsar #1 - 1.6L ~70kw
5. N13 Pulsar #2 - 1.8L ~95kw
6. N13 Pulsar #3 - 1.8L (CA18) ~170kw
7. R33 MACHINE!!! - 9.6L (stroker!!) - ok, 2.5L ~200kw (165 at wheels).
16L - 830kw
i rock!
https://www.sau.com.au/forums/topic/1160-1412-hp-179-litles/#findComment-23725
Rough Estimate...
25x Datsun 1600's average motor displacement = 1800cc, average power output 100kw
Ford XW Falcon 3.8lt approx 130kw
TX3 1.8lt 200kw
180sx 2lt 200kw
R32 2lt 200kw
Taipan Beach Buggy 1835cc 100kw
Datsun 1000 with 1400cc and 80kw
Datsun 1200cc with 50kw
Mazda 929 1800cc with 60kw
... I'm sure there's more in ther just can't remember all my cars.
so that's around:
60835cc Displacement
132 Cylinders
3520 Flywheels Kilowatts
All these are estimates only.... but should be pretty close.
https://www.sau.com.au/forums/topic/1160-1412-hp-179-litles/#findComment-24045
  • 1 year later...
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
