Yeah my pedals had all sorts of problems pretty much out of the box..... Took em back and got a replacement unit.... havent used the wheel in a while but from memory the new pedals where much better and didnt get confused nearly as often....
I can only assume there was a bad batch or something...
guys i need help. i've got the logitech driving force (the one that was released with GT3). now i use it on Race driver 2. when the game boots up it says: 'do you want to use the wheel'. ok cool.
BUT
when i use GT4 i cant seem to get it working. it calibrates when the PS2 is booting up, and in some menus i can use the wheel etc to select stuff, but when i start a race only the controller works. i cant find an option anywhere to chose the controller. I have found the menu where you can allocate certain buttons, but no where can i chose it.
please help!
BUT
please help!
That sounds like the kind thing mind does some times too. I unplug it and replug it in on the first menu, it then re-configs and its ok, then the pedals shit themselves!
Mine has alway had the problem since I got it out of the box.
CRAP! maybe it's a GT4 thing then? cause it works flawlessly with V8 race driver too, but i'm itching for some 'ring and tsukuba laps.
so you reckon try unplugging whilst it's on the 'map' menu or the main menu thing. and will i get a screen that says "do you want to use wheel" or something like that?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their reliability is proven, performance can be predictable, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
