Whats the deal, I've heard that now through compliance Xenon headlights must be removed and in some cases destroyed, is this true? Whats the deal? Whats the ruleing? Every freakin lexus has them and every second commodore.
Edited by ookami
https://www.sau.com.au/forums/topic/116209-r33-series-3-complaince-qs/
I too would like to know. What is the deal under SEVS compliance?
In specific, I have a series 3 BCNR33 that will be arriving and
complied in the next couple of weeks - and there is no way i'll be letting anyone
destroy genuine xenon headlights from Nissan.
Australian Nissan dealerships have quoted me figures of approx $1650 per unit
- so over $3k worth of genuine parts to be destroyed? :D
yeah but is illegal too. The bulbs in theSeries 3 are too bright by australian standards. They apparently use to just replce them with dullar bulbs but people use to replace them with original ones. For Some reason the government thinks that this can't be done to conventional Halaogen headlights, either way governemnt says my lights need to be destroyed.
They dont comply with ADR, not because they are to bright( they are only 35 watt), its because under current ADR they must be auto ajust and have washers on them. The easiest way to make them comply is to convert to hals, thats the reason they all do that .
correct...............:D
i've also since been told the halogen conversion
on this type of lens ruins them - the reflectors and shape
are designed for Xenon, hence converting them to halogen
makes them duller than a normal h1 headlight
Thats true, when you convert them to hals you cant see when it rains at all, they are pathetic.
How does that work? When was the last time you saw a IS200/300 with washers on them? Or even a VY\VZ calais or statesmen?
i've since been told by another industry
person approx $1300 - still puts them up in the expensive
catergory. What do you think they sell for new from Nissan?
$1300 for what? I thought you said you bought a set of series 1 lights to put in? Just swap them back to the S3 lights after its complied/registered.... you can do that yourself, won't cost you anything
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
