Hey guys,
Been reading on this forum for quite some time now and now finally deciding do to some purchasing of an r33.
what i was wondering is what peoples opinions are of an r33 gtst coupe(most likely series 2) being used as a daily driver. I have wanted one for quite some time now but because of age and insurance always decided against it. I am planning on using my line to take me to work and back everyday, which is a 40km drive(usually 1 hr), so 80km a day on weekdays.
What I am basically asking -is this a bad idea in your opinion? ;) What would be the pros and cons of this?
Cheers guys. :D
https://www.sau.com.au/forums/topic/116231-little-adviceopinions/
Umm I wouldn't see a problem in using it as a daily driver... Just about everyone on here does.
Pros on it would be you get to cruise for along time everyday in a Skyline :D
I guess ull be clocking up some k's on it quick.. but hey cars are ment to be driven!
With the fuel prices its gonna cost abit each week.
At 80K's a day you'll go through a full tank of premium per week so its up to you if you could afford it, assuming you get around 430K's out of a tank - ~$70 nowadays
For me, the highlight of the day is the drive to and from work so its worth it hehe
Good points guys.
Petrol will be no problem, plus I have plans to get my hands on a power fc and some kind of ebc.
Should have mentioned that one of the things that has me worried is reliability. At the moment I am driving a 92 Ford Falcon which is a work horse but a real bore to drive.
Mods will be kept fairly simple as I'm not searching any numbers(will c if I can keep this mindset once i've purchased the car :) ). plans are power fc, ebc, fmic, tbe, air filter and other suspension and brake mods.
I dont plan on keeping the ford. So am I gonna be spending most of time in hire cars while my car is in the workshop? :rofl: or can someone here speak on experience and say I should be ok?
Maybe a gtr would be a different story?? :ermm:
Depends if you buy a lemon - get a prospective buy checked out thoroughly (compression test!).
The RB25DET is a very reliable engine and can handle mods. Just don't expect 2JZ internals when you strap on a turbo and run hi boost.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
