Originally posted by rob77
In the latest HPI mag there is a white r34 GTR build up locally by Xspeed... Damn nice car, yet to see it on the road though. Check it out, some people have too much money and need to give me some :D
The wide body kit on that beasty looks pretty tidy..
fairly hauls too, he was at wanneroo for race scar getting it filmed, almost went for a large excursion off the track in style but managed to save it..
https://www.sau.com.au/forums/topic/11624-xspeed-r34-in-hpi/#findComment-201462
Xspeeds white R33 (IYO) is the true beast could be WAs first
10 sec GTR if we can get mario to let Ant run it.
Has nearly 100rwhp and heaps more torque thanND4SPD did when Ant ran low 11s and the best power curve I've ever
seen.
Ants car will kick when he gets it finished as it ran low 11s on
a STD motor.
https://www.sau.com.au/forums/topic/11624-xspeed-r34-in-hpi/#findComment-201644
nice car hey
jan showed me inside of it once!
wish i could be taken in a ride in it
i would cream my pants lol!
steve i seen that (IYO) r33 at ur shop
and at xspeed
it does look like a beast! verrrry nice!
i added to the whiteness of the car when i saw it
hehehee
adrian :)
https://www.sau.com.au/forums/topic/11624-xspeed-r34-in-hpi/#findComment-202032
Originally posted by kidd
my gfriend knows that r34 dude. claims hes a jerk!! keep telling her to call him and let me drive it. anyway jason if u r in here emma sed u r a jerk(sorry bro)
OT sorry but i think that's a way out of line comment .
If Jason is on the forum , how is he going to feel ?
I am sure there are members on this forum who know Jason and think he is OK so now now you have just alienated them against you.
And to be perfectly blunt , I don't give a toss what your g/f thinks.
It's these sort of antagonistic comments that the older members ( ie. those who have been on here more than a month ,eh kidd ) are complaining about.
If you have nothing nice to say about someone , say nothing !
especially on a public forum.
Cheers
Ken
https://www.sau.com.au/forums/topic/11624-xspeed-r34-in-hpi/#findComment-202438
c red tunings red gtr is king of dem all!!!! wish i had $90 grand
Hmmmmm, GTAAH is now the king there.... i think that GTAAH has the Big Red Heart!.... I would expect that to do 10's.
Jash if youre reading this how many secs do you recon GTAAH would get down the quarter, also how do you think it compares to the R34 GTR.
I do agrree though Big Red was pretty sweet.... unfortunately i didn't have 90k lying around:mad:
https://www.sau.com.au/forums/topic/11624-xspeed-r34-in-hpi/#findComment-202650
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
