Location of parts is western surburbs of Melbourne Victoria. Parts are off a 1996 r33 gts-t series 2. Pm me or sms me on 0411825257 and i call you as not near the pc and not always able to check pc due to workloads at work. So if you want a fast repsonse sms me.
FOR SALE
ONE pair of r33 GTS-T front rotors, great condition. No cracks or Hot spots. Have just had them machined and refitted to car to test and then taken off as i upgraded me rotors. Not sure if i mearsued thickness corretly but the min thickness of rotors came to 29mm. from one side to other, no pics at the mo but can send some via email. will be added to post tomorrow night. Not i have only machined disks once and that was 3 weeks ago.
Price $100 for both.
1x OEM/stock AFM for series 2 skyline with plug.
Price $150
1x Series 2 M-spec rear wing white
Price $40
1x set of OEM/Stock springs. set of four (NOTE Also have stock struts and pedders lowered springs on ebay.)
Price $60
1x Fuel Pump
Price $70
1x OEM/stock computer for series 2 skyline, no speed cut and mounting brakets.
Price $150
1x set of r33 skyline rims and tyres
Price $450
Nissan Skyline 16 Inch Stock Wheels and tyres, x 4 (Four rims and four tyres, this will suit any series 1, 2 r33 GTS-T Or car with an offset of, +40 and PCD 114.3. Note rims are 16 x 7.5 inch as taken out of owners manual, if not let me know. These rims are not buckled and are in quite good condition see pics. The tyres that come on this rims are Bridgestone Grid 2. Three has quite good tread and one is on the tyre wear indicators. Also one rim has a small nail in it which can be taken out and repaired, see pic. Note will also supply the original Nissan factory lock nuts that suit there rims. These rims can also fit larger tyres like 225/50/16. Also these rims are perfect for cars that are used for drifting and tyres are good for drifting or road use as tread. In regards to tread wear would estimate tread wear on the best tyres as 70%, could be wrong as they are quite meaty still. Other two about 60% and 30%. Will not post pickup Only. Any questions please send me a message, questions welcome.
post-13838-1146662916.jpgpost-13838-1146663043.jpgpost-13838-1146663063.jpgpost-13838-1146663161.jpgpost-13838-1146663182.jpgpost-21387-1125827144.jpgpost-13838-1146663272.jpgpost-13838-1146663340.jpg[attachmen
=34965:attachment]post-13838-1146663396.jpgpost-13838-1146663419.jpg[att
https://www.sau.com.au/forums/topic/116271-r33-gts-t-parts-cheap/
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
