Location of parts is western surburbs of Melbourne Victoria. Parts are off a 1996 r33 gts-t series 2. Pm me or sms me on 0411825257 and i call you as not near the pc and not always able to check pc due to workloads at work. So if you want a fast repsonse sms me.
FOR SALE
ONE pair of r33 GTS-T front rotors, great condition. No cracks or Hot spots. Have just had them machined and refitted to car to test and then taken off as i upgraded me rotors. Not sure if i mearsued thickness corretly but the min thickness of rotors came to 29mm. from one side to other, no pics at the mo but can send some via email. will be added to post tomorrow night. Not i have only machined disks once and that was 3 weeks ago.
Price $100 for both.
1x OEM/stock AFM for series 2 skyline with plug.
Price $150
1x Series 2 M-spec rear wing white
Price $40
1x set of OEM/Stock springs. set of four (NOTE Also have stock struts and pedders lowered springs on ebay.)
Price $60
1x Fuel Pump
Price $70
1x OEM/stock computer for series 2 skyline, no speed cut and mounting brakets.
Price $150
1x set of r33 skyline rims and tyres
Price $450
Nissan Skyline 16 Inch Stock Wheels and tyres, x 4 (Four rims and four tyres, this will suit any series 1, 2 r33 GTS-T Or car with an offset of, +40 and PCD 114.3. Note rims are 16 x 7.5 inch as taken out of owners manual, if not let me know. These rims are not buckled and are in quite good condition see pics. The tyres that come on this rims are Bridgestone Grid 2. Three has quite good tread and one is on the tyre wear indicators. Also one rim has a small nail in it which can be taken out and repaired, see pic. Note will also supply the original Nissan factory lock nuts that suit there rims. These rims can also fit larger tyres like 225/50/16. Also these rims are perfect for cars that are used for drifting and tyres are good for drifting or road use as tread. In regards to tread wear would estimate tread wear on the best tyres as 70%, could be wrong as they are quite meaty still. Other two about 60% and 30%. Will not post pickup Only. Any questions please send me a message, questions welcome.
post-13838-1146662916.jpgpost-13838-1146663043.jpgpost-13838-1146663063.jpgpost-13838-1146663161.jpgpost-13838-1146663182.jpgpost-21387-1125827144.jpgpost-13838-1146663272.jpgpost-13838-1146663340.jpg[attachmen
=34965:attachment]post-13838-1146663396.jpgpost-13838-1146663419.jpg[att
https://www.sau.com.au/forums/topic/116271-r33-gts-t-parts-cheap/
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
