Greetings from the VERY rainy Gold Coast! We have 2 cyclones near here to contend with atm .... not happy Jan! Went to Sea World today and got rained on all bloody day ..... oh well was fun anyhow. Had a blast and absolutely beautiful weather Sunday for O'Reilly's Plateau tour (boardwalk in the top of rainforest trees), also for Monday at Dreamworld and Tues at Movieworld ..... so I can't really complain!
Back to the topic .... me the leader? .... bwahhahahahahahahahahahahahahahahahahahahahahahahahahhahahaha .... sorry just picking myself up off the floor :P ... anyways .... Brad - you know you can always have a passenger seat with me :(
So the ideas ..... yeah I'm up for any of the above suggestions. I especially agrre with John that if we're gonna go skiing we better go soon before the weather turns nasty!
But I'm up for anything! Catch you all and will elaborate when we get back Sunday!!! Gotta go for a surf now :P
  • Replies 88
Nothing like spending 10yrs as a bodyboarder on Sydneys inner city breaks to learn how to cope with aggro in the water :( And then for the total opposite, actually finding anyone 'keen' to go for a session @ Eagle Hawk Neck Reef (Tassie - my old local break) on a gloomy 8'-10'+ storm swell (300 yard paddle over known pointer territory!) But the big pits & end bowl is WORTH IT :)
k we should get something planned - but next weekend is a bad option since we are having Drifty's cruise Friday night (I'm looking forward to that one!). Two SAU related events in one weekend is a bit much (for the missus to bear :D )
Then the drags are on the weekend after (5th)
Then it is my 1 year wedding anniversary the weekend after (don't even try to get me to go out that weekend - I value my life)
.... so unfortunately it looks like I am out till the weekend 19/20th April.
Hmmmmm
If u all wanna do something sooner then organise away - but my hands are tied till then :D
It will be a reasonable SAU gathering at the drags on the 5th so why don't we organise some name tags etc and have a bit of a proper social gathering there? Someone could bring a barbie and esky and we could do it in the dirt :(
What are you saying Pawley only women should cook. Im half offended, When you do it for a living atleast 10 hours per day there is only so much I can handle. Was your car up at the Shops near the Bremen pub the other day. Id take up two parks too with your car.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
