DOUGMO Posted May 3, 2006 Share Posted May 3, 2006 WILL A COMPLETE DIFF CENTRE IN THE HOUSING SWAP FROM A 94 R33 GTST INTO AN 89 R32 GTST??? Link to comment https://www.sau.com.au/forums/topic/116301-r33-ser-1-gtst-diff-into-r32-gtst/ Share on other sites More sharing options...
R32Dreamer Posted May 4, 2006 Share Posted May 4, 2006 The simple answer is no... I to am looking at the possibilities of usign an R33 aftermarket LSD centre in my R32 GTS-t. The answers i've had so far is that the centre's SHOULD be interchangable BUT the housings are quite different. R32 has 4 studs coming out the back of the inspection plate, where as an R33 only has 2 large studs. Also the two mounting holes towards the front are different in size. These two problems can be overcome by swapping the inspection plate and using the normal bushings from an r33 to reduce the bolt hole size. The DEATH BLOW is the housings are of a different length... so unless the r33 rear drive shaft is smaller than an r32's and it can be used in your 32 then this an impossible swap... Sorry, Goodluck p.s. look into the drive shaft lengths, you never know. Also look into having the centres changed. Link to comment https://www.sau.com.au/forums/topic/116301-r33-ser-1-gtst-diff-into-r32-gtst/#findComment-2140726 Share on other sites More sharing options...
DOUGMO Posted May 5, 2006 Author Share Posted May 5, 2006 THANKS MATE, I THINK ILL JUST SWAP THE CENTRES OVER Link to comment https://www.sau.com.au/forums/topic/116301-r33-ser-1-gtst-diff-into-r32-gtst/#findComment-2141733 Share on other sites More sharing options...
