Hi, will installing a pair of HKS cams (EX280 10:01 - IN272 10:08) require all new valve tip shims (in general)?
I know they need to always be checked, I'm just asking, on average, do most guys with stock heads require buying all new thicker/thinner shims to install these cams?
thank you
j.
https://www.sau.com.au/forums/topic/116308-hks-step-2-cams/
It depends on the base circle of the cam as to whether you'll need the longer aftermarket buckets, but as for shim size pretty much after any cam swap you'll need to change/machine them for the correct lash.
Reason I ask is I already installed a unknown brand of cams (264/9.7 - 256/9.7) and all the stock shims worked out perfect on that swap.
I've heard of some cam makers keeping the base stock so that the stock shims do work. Just wondering if anyone has installed the HKS step 2 cams, and if so, did they need new shims....?
thanks - j.
https://www.sau.com.au/forums/topic/116308-hks-step-2-cams/#findComment-2138978
Shims should be meaured and adjusted for each valve. This must be checked with a feeler gauge. I wouldn't just swap and hope for the best even if they say its OK. You should be accurate to 0.01mm or very close to this.
Edited by WetGTR
https://www.sau.com.au/forums/topic/116308-hks-step-2-cams/#findComment-2141329
I know all that.... I keep asking the same question but get answers to something else.
I ask, from someone who knows, in general, do you have to buy all new shims when you install HKS step 2 cams on a stock unmolested head?
I know I should check the clearnces "after" the cam swap. I'm trying to plan ahead and know if most that have done this ended up buying all new shims.
thanks again - j.
https://www.sau.com.au/forums/topic/116308-hks-step-2-cams/#findComment-2141356
thanks again - j.
:O and again.......i used HKS step2 264 cams with the same lift as yours........I machined releifs for the cam lobe....and reshimmed the valves.....how can they say you have to or dont have to reshim....all depends on so many variables....valve wear, seat wear ect
https://www.sau.com.au/forums/topic/116308-hks-step-2-cams/#findComment-2141609
:mrt: and again.......i used HKS step2 264 cams with the same lift as yours........I machined releifs for the cam lobe....and reshimmed the valves.....how can they say you have to or dont have to reshim....all depends on so many variables....valve wear, seat wear ect
ok, so you bought 24 new shims. Thanks, thats what I needed to know...
https://www.sau.com.au/forums/topic/116308-hks-step-2-cams/#findComment-2141868
I'll make it easy
Case 1: Cams are standard base circle (32mm) - Which I think the HKS Step 2's are...but check
-> If you just drop the cam in, the clearance will be the same as it was before you did the cam swap, as the only thing that has changed is the camshaft. The only part of the cam lobe that determines the valve clearance is the back of the lobe, and this should not be worn.
HOWEVER, of course you should fit the cams and check clearance with a feeler gauge.
ALSO, you will probably find that on an old engine, the clearances will be a little on the high side due to wear on the lifters, shims and valve stems. But re-shimming is painful and expensive, so as long as the clearances are acceptable, you may be better off fitting the cams and setting the clearances properly if you ever pull the head off. Most guys that do heads don’t buy shims they just set the clearance by taking a touch off the stems when after they have cut the valves / seats.
Case 2: Cams are non standard base circle (32mm) – Tomei, Jun and others.
This is done so you can run big lift without flycutting the cylinder head. In this case, you will either need to reshim the entire head, or buy lifters with the correct offset for your base circle. If you use the right lifters, theoretically, your valve clearance won’t change, but there will be too many variables so you should reset.
https://www.sau.com.au/forums/topic/116308-hks-step-2-cams/#findComment-2142039
no i didnt buy that many shims......fit the cams in the head....measure the clearance...write them all down in order take the shims out messure them then swap them accordingly......unless you have o clearance on any of the valves then you find the smallest shim you have and put the cams back in again and get a starting clearance from there
https://www.sau.com.au/forums/topic/116308-hks-step-2-cams/#findComment-2144097
    • Hi everyone, just looking to see what's available in the GTR seat options, testing the waters on what's available. Wanting a driver's seat to replace my old school OG jap race seat, going to re-register the car so need a factory seat. Prices currently seem to go from $300 to $2k for a driver's seat. What's options are there, that's good condition and actually a realistic price? Located Brisbane. Thanks
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
