So I was walking down George St at lunch today and a bus pulls up near me and PSSSSHT.
I was less than 1m than the bus... so 2 questions come to mind.
a. why dont they get defected? (and this is PURELY rhetorical so dont up shit about this)
b. why can't I sue them for hurting my ear?
... anyone wanna take my case on?
https://www.sau.com.au/forums/topic/116330-buses-and-bovs/
Its public transport... the government couldnt give two shits about peoples ears if its saving them money.
EXACTLY!!!
Why can't you have a fulsikhectic megaphone BOV in ur car if it uses MAP fueling?
Standard Cop response- " 'Cause it's noise pollution, sir."
WELL WHAT ABOUT THE FKN M#$%ERF#$%ER BUSES THEN???
https://www.sau.com.au/forums/topic/116330-buses-and-bovs/#findComment-2139378
Not a BOV, it's the air compressor unloading.
When the air sysyem pumps up to working pressure, about 120psi, the compressor unloads and freewheels. The noise is the air released from the pipework between the compressor and the unloader valve.
Air brake noise is the air released from the brake system when the brakes are released.
Engine brake noise ( Jacob's engine brake) is much much louder and not usually heard in cities for obvious reasons.
Proper diesels don't need BOV's as they have no throttle butterfly. Only toy stuff like the old Toyota diesels had a butterfly as a cheap way to get vacuum for the brakes.
https://www.sau.com.au/forums/topic/116330-buses-and-bovs/#findComment-2140400
I thought the deisels still had something like a BOV because on the biggins trucks, Big rigs and stuff, you hear the high pitched "powwwwwww" sound between gears.
Not a whistle, not a hiss, a "powwwwww"
make sence?
https://www.sau.com.au/forums/topic/116330-buses-and-bovs/#findComment-2140413
Well, diesels, turbo diesels too have no throttle, its all controlled by the injectors and not a throttle plate, so seeing as backpressure is created by a pressure difference between the manifold and turbo outlet pipe when a throttle plate closes, they dont have to worry about a pressure wave going the wrong way down the tube and belting into the blades.
Considering even most of the little 4cylinder turbo diesels seem to run a minimum of 14-15psi and trucks run about 40+psi and they dont have a BOV it seems surplus to requirements.
Theres all kinds of pnuematic assistance on big trucks and buses for all kinds of shit, not sure which shit it is making the noise I'd have to ask my dad he used to work for International.
edit- and yes in noisy environments with trucks using compression brakes, buses and noisy fuggen bikes I hardly think some noob with a noisy BOV is hardly going to kill anyone from a ruptured eardrum.
Edited by MK2
https://www.sau.com.au/forums/topic/116330-buses-and-bovs/#findComment-2140520
It would all be pnuematic reliefs. Buses like trucks use air, as its inifinite in supply, so long as the compressor is filling the tanks, and there are no leaks or wankers constantly hitting the pikes for no reason.
The noise people talk about when they change gears cant really be anything, unless that certain truck has an air assisted clutch...but truckies with some ability dont use the clutch at all unless they are stopping, starting, engaging PTO and in some trucks like volvos engaging splitter for high range (not all trucks have to use the clutch for this). I work around trucks a fair bit, and i drive them around occassionally around and out of the yard. So yeh...who knows, might be some truck with mechanical issues and is making funny noises.
Edited by r33_racer
https://www.sau.com.au/forums/topic/116330-buses-and-bovs/#findComment-2140570
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
