For some of the people in this post who didn't get what I was saying-
- it's not a fault. all buses do it of certain make(s) do it.
- i didn't say it was necessarily a bov used for turbos. it is air escaping so it's "blowing off" in some form or another. personally i think it's the door/brake pneumatics.
- it hurt my ear and I want to sue the government (not serious) so what would i do? why isn't this noise pollution? (does anyone know if it's just accepted or 'enshrined' in law somewhere?)
... ps.
Can anyone tell me where to get one of these bus BOV's? and is there an adaptor to fit them to my laser turbo?
SIK WLEH BROTEC comes to the rescue.. PM me for a good price.
You sure thats an exhaust brake?
Not saying your wrong but I drive trucks and have not seen one set up like that before. I have only ever seen the butterfly flap in the exhaust pipe and the Jake brakes which hold the valves shut for the engine braking. How does that one work.
In relation to to BOV noise, as mentioned its the pneumatic release from the air brakes and in a bus situation from the airbag suspension as well. Sometimes when there stopped on a slope you see a bus rocking forward and backwards as the airbags try to level themselves.
I look at the engine setups on our trucks all the time and I have no friggin idea whats going on. One engine has an internal wastegate along with an external gate as well that seems to vent back to the inlet manifold?
And on the inlet piping they have multiple pressure actuators that I have not a clue what they do, when they open/close and what for.
couldnt they suppress it something? it shouldnt need to be that loud...
it real bad in a loading bay, the truck reverses in and the brakes squeels a little before it stops, then PPPPSSSSSSHHHHH!!!!! and you nugget your pants :/
Yep, that's an exhaust brake. A Jake brake uses oil pressure to the hydraulic lash adjusters which cracks the exhaust valve on the compression stroke preventing the compression ignition combustion (no spark plugs) from completing so it "brakes" the engine.
Don't be afraid big rig and bus noobs, the noises won't hurt you. :P
Its can also be height adjustment
Thats air driven aswell (esentially air bags i think).
SOme super new buses can change ride height depending on passenger load.
They too can be noisy. Not as loud as the compressor veniting though
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
