Okay, i went to the NGK website and found the part numbers for the o2 sensors that should go in my R32 GTR, but i have rung around and no-one has them in stock, they are NGK-OTD2F-P1P, but then i went searching and found that the nissan silvia SR20DET engine uses the same plug...but to add to that, i went to but some o2 sensors for a SR20DET and the dude is telling me the part number is NGK-OZA395-E2. will these work or do they need to be the OTD2F-P1P sensors? and where can i get them from if anyone knows :S thanks...
https://www.sau.com.au/forums/topic/116364-gtr-oxygen-sensors/
Me? I have a set for sale R32 GTR :P
http://www.skylinesaustralia.com/forums/in...opic=115107&hl=
There are two part codes for GTR sensors are they are different connectors on each sensor (front to rear)
Nissan is where everyone gets them from as far as i understand... although they want $420+
You didn't search very well :P
http://www.pcug.org.au/~jdeakins/facts.html
PM "GTaaargh" and ask if he has the NGK part numbers (and a source) for the front and rear as he has been in touch with a tech at NGK.
Otherwise, now is a good time to become an SAU member and take advantage of discounted Nissan parts. Or buy Ash's O2 sensors.
ford el falcon series happens to suit R33 GTST only.
it just happens to be in same voltage scale and range.
If you ask for a ford el falcon oxygen sensor you get an OEM generic brand oxygen sensor and it just happens it fits the R33 dump and voltage matches
if your trying to improve fuel economy I have looked into this too.
Most people i have spoken to get 300-350kms per tank around town so in my case thats what I'm getting, so I am going to save my money in the o2 sensor departmant.
I wish I could get better than that!
good luck.
    • Sounds like the solenoid might be cactus, if the solenoid trigger wire was still attached (and it was just the main power to the starter itself remove). Just to provoke Neil haunting me for the rest of my life... Have you tried tapping it with a hammer while someone switches the key to start? This might work for the fuel pump too... šŸ˜›
    • I need help dealing with an engineer who is massively overcharging me for an engineering report on my modified, written-off Jeep to get it roadworthy. šŸ”¹ Initially, he quoted me $3,500 - $4,500. šŸ”¹ First invoice: $5,315 (already above the quote). šŸ”¹ Second invoice: $1,375. šŸ”¹ Now, he has sent another invoice for $3,100! This is way more than double what I was originally quoted. I feel like Iā€™m being ripped off. Has anyone dealt with something like this before? What can I do? Any advice on how to report him or fight these unfair charges? Would really appreciate any guidance! šŸ™ Am in Adelaide.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
Ɨ
Ɨ
