are you willing to sell the greedy piping separately? if so how much?
also are they z32 afm's? i already have them but need filters to suit... they for sale at all?
cheers
yeah still for sale, at this point want to sell with the turbos thanks
ps:filters and air flow meters doesnt come with this package. Only piping n clamps n turbos x 2
https://www.sau.com.au/forums/topic/116398-please-delete/#findComment-2144564
Item:HKS 2530 X2 TURBO FOR GTR WITH Greddy hard piping
Item Condition:USED IN GOOD CONDITION
Reason for Selling:Upgrading
Price and Payment Conditions:PICK UP OR DIRECT DEPOSIT, ASKING $3600 neg
Extra Info: This is set up is on my car still.
Contact Details:
NOT willing to separate turbo's so please do not ask thanks (unless have 2 buyers)
EDIT will include manifolds and dump and front pipes
Hi mate,
Are the dumps and manifolds stock? If not what brand are they?
Did you buy the turbs new or used? Estimate on km's travelled?
https://www.sau.com.au/forums/topic/116398-please-delete/#findComment-2152304
Hi mate,
hi dude
it came with the car so dont know what actual brand it is...looking at them from engine bay they look stock to me but cant be 100% as the heat shield is blocking view....turbos around 30K ..they still on my car and mines a daily driver so nothing wrong with them. Selling cos want to go single and wont need any of the twin setup...the front pipes are kakimoto tho.
https://www.sau.com.au/forums/topic/116398-please-delete/#findComment-2154423
    • Not too sure just yet, want to have a go at doing what I can myself, but to start with want someone to cast their eye over it tell me what needs doing to get it running and back on the road, so anyone with great overall knowledge would be ideal.
    • I personally would go with cutting out the rubber. Then deal with getting sleeve off separately. Rubber can be painful to cut, it loves to jam up cutting tools. I normally have success with drill bits, deburr bits, angle grinders, jigsaw, reciprocating saw, and never forget... fire. Obviously different tools won't work in all locations you're trying to work with, and you need to be comfortable with each. You personally may be happy slowly slicing it out with a razor blade, if you are, go for it with one too! Feel free to wait for others to weigh in also on their thoughts.
    • So ... I got everything disconnected and started dropping the frame. Three of the four mounts started to come down but the fourth one (the one with the nut that gave me all the trouble) won't budge. The inner metal sleeve stays up tight against the chassis rail although the outer part of the mount drops a bit (and can be levered quite a lot more) but it's just stretching the rubber bushing. So I reckon there's some serious corrosion inside the inner sleeve and holding it tight to the lug at the top of the bolt. Tried everything I can think of so far: penetrating oil, whacking the top of the sleeve to vibrate it and wedge a screwdriver blade in there. I also tried to turn the inner sleeve a bit by hitting it with a chisel at the bottom. It's stuck solid. What do you think about cutting the rubber with a blade so I can drop the subframe around it anyway. Then worry about getting the inner sleeve off after? Will that work? Is it gonna give me even more problems?
    • Steam valve seals are usually responsible for cold start smoke, it goes away once engine warmed up. Disconnect it let engine breathers and let it breath freely, see if problem goes away after a short drive. Also check to make sure engine oil drain pipe is not blocked or kinked.
    • Haha thanks! Yea I'm moving over from 2x 1000cc jets pre throttle over to 6x 190cc direct port jets and 1x 500cc pre throttle jet.  Direct port comes with all the advantages you would expect, except that pre throttle does cool down IAT'S more. That's why my direct port nozzle placement is closest to the plenum as possible in the runners to allow the air more time to cool before being sucked in. I'm also putting that one 500cc pre throttle jet to help with more cooling. It's a hybrid system. There's a lot more advantages to moving over to a PWM solenoid with a constant pressure system vs my old PWM pump setup, but I'll get more into that once I'm done converting everything over. The ricer in me is excited to see SS tubing all over my manifold though!
