hi just wondering if anyone can help me with my line.Recently when i start my cartheres a loud rattling\knocking noise.Also the car will not boost at all.It will go up to the half way line on the stock boost guage but not any furthur.The car feels extremly sluggish and unresponsive.But after you drive for about 5 mins the noise goes away and the car will boost.Even then when the car idles it keeps skippng quite alot like its about to stall.Does anyone know whats wrong.
https://www.sau.com.au/forums/topic/116416-gtst-problem/
Umm... the stock gauge is in mmMg... not PSI
So about half on the gauge is around 7-10psi which is correct.
I would advise getting a boost gauge as the stock one is hardly reliable at the best of times
https://www.sau.com.au/forums/topic/116416-gtst-problem/#findComment-2141005
with an exhaust leak
it will sound really loud and farty
it will take a while to come on boost (lots more lag)
as the exhaust backpressure is leaking
also fuel economy will suck the wang.
if you have an exhaust leak is it onl vageuly present at idle (ie: you can only just tell) but if you rev it, its dead obvious. a bit like an old tired volkswagen beetle
https://www.sau.com.au/forums/topic/116416-gtst-problem/#findComment-2141159
if it is in fact the exhaust leak its just the gasket fails.
mine failed @ 145,000. it basically fails to seal anymore and blows a hole in it. this results in an exhaust leak. it comes on full boost eventually just takes a bit longer as the backpressure isnt as high. you need to replace which ever gasket has failed
1) exhaust manifold
this is between the engine and manifold. its a long 6 port one.
2) dump gasket
this is between the dump pipe and turbo exhaust housing.
3) turbo flange gasket
this is on the one between the turbocharger and manifold
this was the one failed on my car
the full gasket kit costs $150 but its a fair bit of labour to have it all replaced as all that crap has to come off and be unbolted. and its also likely some of the exhaust studs will snap (i had 2 snap) which takes more labour to get them out.
are you in melb? i can have a quick listen and confirm if its exhaust leak
https://www.sau.com.au/forums/topic/116416-gtst-problem/#findComment-2141186
  R33-Gts25t said:
wat can cause an ehaust leak
https://www.sau.com.au/forums/topic/116416-gtst-problem/#findComment-2141357
