Z32 Afm Adapters
Swiper the Fox
 Share
The DiRTgarage machine shop is considering doing a "run" of these adapters if given enough interest, as producing "one offs" are a bit exy (around $80 ea for time and materials) but if we can get some interest we may produce these for about $60 for a run of 20 or about $70 for a run of 10. So we are currently taking names and if enough interest we will get them underway. The adapter is made from similar material to the body of the meter, is heat resistant and also gives that OEM appearance. A milled finish on the flat surfaces and a smooth turned tapered finish on the "snout".
EDIT: these can also be made from aluminium if desired
Edited by DiRTgarage
Guest
 Share
