Put my Series 1 RSFOUR on the Dyno last night to see if it made factory power and look at the A/F's. It made 180rwhp (had front driveshaft disconnected for RWD dyno'ing) at about 6500rpm on about 6-7psi (factory solenoid high mode). So if you figure on 240hp @flywheel, and maybe 25% losses then 180hp is about right.
But it was superduper rich throughout which I kinda see as a problem! At idle it achieved 13.5-14.5:1, so made me think the o2 sensor was working in closed loop mode, but at cruise (about 10in. Vac - 2000rpm - 4hp) it went straight to between 11.1 - 11.4 :1, stupidly rich. And on a full power run it goes off the meter at the top end, running around 10:1 before meter says 'too rich' and stops measuring.
I discovered the factory bov was leaking when we pressurised the intake path with an air compressor to check for leaks (had to disconnect and block the bov recirc line to check for bov leakage). So tried another std nissan bov they had lying around, it too leaked (both leaked from 2-6psi). Wondered if other ppl's might be? I squashed mine up in the vice to increase spring tension (butcher I know but gonna replace it), but still leaked. But it's full recirc after afm, so wouldn't be causing richness.
Sooo I'm thinking i'm on a hunt for faulty components causing the richness before I just tune it out with a piggyback. If something's wrong best I fix it instead of just tuning away.
But I'm wondering if other guys with std Stagea's have seen similiar A/f's on the dyno???
https://www.sau.com.au/forums/topic/116446-super-rich-stagea/
Stock NIssan ECU's = SUPERMEGAHAPPYRICH fuel mixtures, my stock R33 ran as low as 7.5:1 running stock ECU, I would assume that the stock Stagea ecu would be about the same..?
All the RB25DET stock BOV's leak, if you do some searching you'll find out all kind of stuff about the stocker BOV.
I have a feeling that the Stagea ecu is slightly different, in the outer case at least), as in you cant read error codes on the ecu on a stagea but can on an R33 (true?).
I suggest getting a SAFC and tune that beast! 12:1 all the way.
Sweet I'm pleased to hear my car probably isn't broken and slammin' rich is the norm. You'd have to ask why though.. like what was running through the ecu engineer's mind? I know altitude - temp - etc but shit.
I'm probably planning on Greddy e-manage 2, supposedly they're the way. Dyno guy is tuning on one a car soon so he'll say how it goes. Bout 1k to buy, and has usb connection, designed for tuning with laptop which i figure is handy (if ya got one).
Tangles, is the SITC a little blue screen version of the ITC? I never knew they existed!
SITC had 5 dials that you can alter the Ignition Timing on....... no screens, although they give a nice glow when the powers on.
Apexi Super-ITC or Super Ignition Timing Converter
see SK's thread, pics and all: http://www.skylinesaustralia.com/forums/in...c=80642&hl=sitc
Edited by Tangles
wicked, im about to pick one up to compliment my SAFCII. It was sold as a ITC not a SITC, so I thought there might have been a difference.
Thanks mate.
No probs!!
I gained 20kw when I added the SITC and a fuel pump (direct wired) & Z32 afm, tuned at 12psi up from 10psi. Best of luck with it.
fyi: I got a Brand New SITC off ebay for $200US LOL, never ever seen another brand new one for sale.
As I said earlier I wanted to get the S1 tuned as I thought it was running a bit rich. 15+/100kms, plus the exhaust is very sooty.
All the technical terminology in this topic puts me off a bit.
What is a simple economical method of getting a tune up?
Take it to a trusted tuner, give him lots of $$ and get your vehicle back with a couple of extra piggyback ecu's and a decent tune. Easy :/
Or buy what Tangles bought, SAFC (Super Air Flow Converter I think..?) or a SAFCII (Same but a newer version) and the SITC (as explained by Tangles) and then install them yourself if you have the knowhow or take them to a tuner and get him to install and tune.
There are heaps of different ways to do this, all depending on price range and what tuner you take it to.
For example I have a Power-FC, which is a replacement ECU, but it had to be dodgy wired in because you cant buy one for a RSFour, but it allows a huge range of tuning capabilities. It would also cost you around the $1500 mark, plus all the stuffinf around to get it to work.
Or there is the GReddy E-Manage, which is a piggyback ecu, but has a lot of features, esp when combined with a Profec E-01. Again fairly expensive from what I have heard, ~$1500........?
Or there are several small piggyback ecu's you can get that do specific jobs, SAFC (Fuel mixture controller), SITC (ignition timing controller), AVCR (boost controller).
It all depends on what either your personal preference is or what your tuners preference is.
Not all tuners know or want to tune all ecu's, I havnt found anyone here in Rockhampton that can tune my Power-FC, mainly because I dont have a hand controller, so they would need to run some sort of program to control the Power-FC, like my old tuner in Brisbane did, meaning if I did want it re-tuned then I will have to drive down to Brisbane for a tune.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
