Spammeoff Posted May 4, 2006 Share Posted May 4, 2006 Put my Series 1 RSFOUR on the Dyno last night to see if it made factory power and look at the A/F's. It made 180rwhp (had front driveshaft disconnected for RWD dyno'ing) at about 6500rpm on about 6-7psi (factory solenoid high mode). So if you figure on 240hp @flywheel, and maybe 25% losses then 180hp is about right. But it was superduper rich throughout which I kinda see as a problem! At idle it achieved 13.5-14.5:1, so made me think the o2 sensor was working in closed loop mode, but at cruise (about 10in. Vac - 2000rpm - 4hp) it went straight to between 11.1 - 11.4 :1, stupidly rich. And on a full power run it goes off the meter at the top end, running around 10:1 before meter says 'too rich' and stops measuring. I discovered the factory bov was leaking when we pressurised the intake path with an air compressor to check for leaks (had to disconnect and block the bov recirc line to check for bov leakage). So tried another std nissan bov they had lying around, it too leaked (both leaked from 2-6psi). Wondered if other ppl's might be? I squashed mine up in the vice to increase spring tension (butcher I know but gonna replace it), but still leaked. But it's full recirc after afm, so wouldn't be causing richness. Sooo I'm thinking i'm on a hunt for faulty components causing the richness before I just tune it out with a piggyback. If something's wrong best I fix it instead of just tuning away. But I'm wondering if other guys with std Stagea's have seen similiar A/f's on the dyno??? Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/ Share on other sites More sharing options...
Ska Posted May 5, 2006 Share Posted May 5, 2006 Stock NIssan ECU's = SUPERMEGAHAPPYRICH fuel mixtures, my stock R33 ran as low as 7.5:1 running stock ECU, I would assume that the stock Stagea ecu would be about the same..? All the RB25DET stock BOV's leak, if you do some searching you'll find out all kind of stuff about the stocker BOV. Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2142704 Share on other sites More sharing options...
Tangles Posted May 5, 2006 Share Posted May 5, 2006 Stock NIssan ECU's = SUPERMEGAHAPPYRICH fuel mixtures, my stock R33 ran as low as 7.5:1 running stock ECU, I would assume that the stock Stagea ecu would be about the same..?All the RB25DET stock BOV's leak, if you do some searching you'll find out all kind of stuff about the stocker BOV. I have a feeling that the Stagea ecu is slightly different, in the outer case at least), as in you cant read error codes on the ecu on a stagea but can on an R33 (true?). I suggest getting a SAFC and tune that beast! 12:1 all the way. Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2142761 Share on other sites More sharing options...
AlexCim Posted May 5, 2006 Share Posted May 5, 2006 on the dyno the other day, i was getting 14.5's off boost and 12.somethings on boost. Not too shabby for a 100% stock ECU IMO Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2143037 Share on other sites More sharing options...
_8OO5TED_ Posted May 5, 2006 Share Posted May 5, 2006 yeah SAFC II is your friend Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2143107 Share on other sites More sharing options...
Ska Posted May 5, 2006 Share Posted May 5, 2006 Alex that is great numbers for a stock ecu! But to properly tune, as everyone else has mentioned a SAFC or SAFCII will make a big difference in power and fuel consumption! Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2143135 Share on other sites More sharing options...
Tangles Posted May 5, 2006 Share Posted May 5, 2006 Alex that is great numbers for a stock ecu! But to properly tune, as everyone else has mentioned a SAFC or SAFCII will make a big difference in power and fuel consumption! SAFC II and a SITC Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2143223 Share on other sites More sharing options...
Spammeoff Posted May 5, 2006 Author Share Posted May 5, 2006 Sweet I'm pleased to hear my car probably isn't broken and slammin' rich is the norm. You'd have to ask why though.. like what was running through the ecu engineer's mind? I know altitude - temp - etc but shit. I'm probably planning on Greddy e-manage 2, supposedly they're the way. Dyno guy is tuning on one a car soon so he'll say how it goes. Bout 1k to buy, and has usb connection, designed for tuning with laptop which i figure is handy (if ya got one). Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2143387 Share on other sites More sharing options...
_8OO5TED_ Posted May 5, 2006 Share Posted May 5, 2006 Tangles, is the SITC a little blue screen version of the ITC? I never knew they existed! Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2143507 Share on other sites More sharing options...
Tangles Posted May 5, 2006 Share Posted May 5, 2006 (edited) Tangles, is the SITC a little blue screen version of the ITC? I never knew they existed! SITC had 5 dials that you can alter the Ignition Timing on....... no screens, although they give a nice glow when the powers on. Apexi Super-ITC or Super Ignition Timing Converter see SK's thread, pics and all: http://www.skylinesaustralia.com/forums/in...c=80642&hl=sitc Edited May 5, 2006 by Tangles Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2143586 Share on other sites More sharing options...
_8OO5TED_ Posted May 5, 2006 Share Posted May 5, 2006 wicked, im about to pick one up to compliment my SAFCII. It was sold as a ITC not a SITC, so I thought there might have been a difference. Thanks mate. Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2143612 Share on other sites More sharing options...
Tangles Posted May 5, 2006 Share Posted May 5, 2006 wicked, im about to pick one up to compliment my SAFCII. It was sold as a ITC not a SITC, so I thought there might have been a difference.Thanks mate. No probs!! I gained 20kw when I added the SITC and a fuel pump (direct wired) & Z32 afm, tuned at 12psi up from 10psi. Best of luck with it. fyi: I got a Brand New SITC off ebay for $200US LOL, never ever seen another brand new one for sale. Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2143655 Share on other sites More sharing options...
66yostagea Posted May 5, 2006 Share Posted May 5, 2006 As I said earlier I wanted to get the S1 tuned as I thought it was running a bit rich. 15+/100kms, plus the exhaust is very sooty. All the technical terminology in this topic puts me off a bit. What is a simple economical method of getting a tune up? Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2144034 Share on other sites More sharing options...
Ska Posted May 5, 2006 Share Posted May 5, 2006 Take it to a trusted tuner, give him lots of $$ and get your vehicle back with a couple of extra piggyback ecu's and a decent tune. Easy Or buy what Tangles bought, SAFC (Super Air Flow Converter I think..?) or a SAFCII (Same but a newer version) and the SITC (as explained by Tangles) and then install them yourself if you have the knowhow or take them to a tuner and get him to install and tune. There are heaps of different ways to do this, all depending on price range and what tuner you take it to. For example I have a Power-FC, which is a replacement ECU, but it had to be dodgy wired in because you cant buy one for a RSFour, but it allows a huge range of tuning capabilities. It would also cost you around the $1500 mark, plus all the stuffinf around to get it to work. Or there is the GReddy E-Manage, which is a piggyback ecu, but has a lot of features, esp when combined with a Profec E-01. Again fairly expensive from what I have heard, ~$1500........? Or there are several small piggyback ecu's you can get that do specific jobs, SAFC (Fuel mixture controller), SITC (ignition timing controller), AVCR (boost controller). It all depends on what either your personal preference is or what your tuners preference is. Not all tuners know or want to tune all ecu's, I havnt found anyone here in Rockhampton that can tune my Power-FC, mainly because I dont have a hand controller, so they would need to run some sort of program to control the Power-FC, like my old tuner in Brisbane did, meaning if I did want it re-tuned then I will have to drive down to Brisbane for a tune. Link to comment https://www.sau.com.au/forums/topic/116446-super-rich-stagea/#findComment-2144438 Share on other sites More sharing options...
