Clearing out all my old/unwanted/not needed stuff
parts from a variety of cars
R33 stock intercooler x2 - $20 each 2 for $30
r33 4 door electric areial thing- no longer available
custom built Hyundai eldantra (xd 2001) front bar, needs a little repair work $75
Unknown 180sx front bar okish condition $100 - see pic below and new price- accepting offers below 100 now will swap for carton of bundy rum
standard r33 front bar with indicators good condition $100 0no - sold
MQ patrol front passanger door, no glass or trim $80 as bought from wreckers, not needed as 4x4 stolen last week
r33 standard front grill $40
r33 front reo support bar $40
r33 4 door sedan rear reo support bar $50
archary set in box, bow and a few arrows, designed for target shooting but great for hitting the odd bird or small animal, include a few hunting tips for bigger live targets $250
more stuff to be added when i find it
some prices neg.
pics provided on request
pm or sms on 0439719822
all items in Brisbane
Edited by teamplasma
https://www.sau.com.au/forums/topic/116492-fs-variety-of-stuff-going-cheap/
this is the 180 front bar, been a while since i've looked at repair work wasn't quite up to the standards i thought so new price of make an offer as is in its current state, repair work's not hard just need some bog or fibreglass in a few areas
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
