Drivebai Posted May 5, 2006 Share Posted May 5, 2006 HEy all. Sometimes early in the morning when i start my car i hear a loud thump sound when the engine kicks over. This only happens sometimes. IF i start the car with the clutch pressed in.. i won't hear the thump unless i release the clutch. Sounds like its comeing from the back of the car but i'm not sure. also sometimes when i'm sitting at the lights and press the clutch in there is a slight thump but you have to listen for it and sometimes you can feel it. Does anyone have any ideas? of course when i take it to the mechanic it doesn't do it!!! The car still drives fine no problems... PLEASE HELP!!! Thanks Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/ Share on other sites More sharing options...
T04GTR Posted May 6, 2006 Share Posted May 6, 2006 hmmmm. Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2144643 Share on other sites More sharing options...
HR-32 Posted May 10, 2006 Share Posted May 10, 2006 save for new clutch Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2153737 Share on other sites More sharing options...
Drivebai Posted May 12, 2006 Author Share Posted May 12, 2006 But the clutch grabs fine though, no slipping or anything.. its weird. REplaced the clutch with a heavy duty one when i first got the car about 3 years ago. Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2162770 Share on other sites More sharing options...
MMM Posted May 13, 2006 Share Posted May 13, 2006 yeah i think mine does this as well.. dont think its anything bad Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2163656 Share on other sites More sharing options...
azn_r33 Posted May 14, 2006 Share Posted May 14, 2006 Mine does the same when its cold. i only replaced the stock one with a Excedy HD sports clutch bout 6 months ago. Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2165087 Share on other sites More sharing options...
ODessA Posted May 14, 2006 Share Posted May 14, 2006 diff ? Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2166341 Share on other sites More sharing options...
Drivebai Posted May 19, 2006 Author Share Posted May 19, 2006 i changed diff oil as well..but still makes that thump sound.. at least i am not alone.. the car still drives fine. to those people who are experiencing the same problem please notify the rest of us if you figure it out or if your car suddenly falls apart. THanks all Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2184344 Share on other sites More sharing options...
Zoggy Posted May 20, 2006 Share Posted May 20, 2006 yeah i think mine does this as well.. dont think its anything bad Same !!!! Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2184516 Share on other sites More sharing options...
RoadHog_r33 Posted June 16, 2006 Share Posted June 16, 2006 Yea mine does this aswell found out it is either the bachlashes on the bearings in diff or possibly the preloads on the lsd section aswell (just had mine replaced) or wear and tear on your universal joints on the tail shaft, its nothing to worry about unless it gets worse i been told but is annoying, but you can possibly have it starting to do open wheelers around corners if it is too loose though. Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2262176 Share on other sites More sharing options...
BL01 Posted June 16, 2006 Share Posted June 16, 2006 Correct me if i'm wrong, the sound most properly came because you are using a H/D clutch. It's the sound of the clutch engaging/clamping with the flywheel. It shouldn't be a problem at all unless u are just particular with the sound. My 2 Cents Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2263376 Share on other sites More sharing options...
RANDY Posted June 16, 2006 Share Posted June 16, 2006 If it's not in gear, how would the clutch be releasing/grabbing anything? Could it be a carrier bearing or something along those lines? Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2263398 Share on other sites More sharing options...
RoadHog_r33 Posted June 21, 2006 Share Posted June 21, 2006 i have this problem i know it not the clutch in mine i had it checked out if the sound comes from mid car or near rear it is either the tailshaft or preloads or backlashes as it is in mine, it only happens when the car actually gets moving and happens no more than 2 secs after its just picking up that little bit of slack in tailshaft or in diff not bad until it gets worse Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2273785 Share on other sites More sharing options...
Guilt-Toy Posted June 21, 2006 Share Posted June 21, 2006 try checking the exaust. sometimes it can move when you start the engine and hit the floor of the car or somehwere in the rear. Get someone to put there foot on the exaust when you start (put some pressure on it holding it in place) and see if you still have the problem. Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2275837 Share on other sites More sharing options...
RANDY Posted June 21, 2006 Share Posted June 21, 2006 Hmm... mine will make a clunk if I push the clutch in while reversing... like if you're feathering the clutch. Never when I just turn the key... I can't see how it would be taking up any slack at all... it's not in gear, so there should be no drive to the tail-shaft or rear diff, or wheels. I like the exhaust option more... I was going to suggest a bad engine mount or something... I guess a bad mount would make the engine jump a bit, which would lift your dump and exhaust system. Link to comment https://www.sau.com.au/forums/topic/116516-loud-thump-sound-when-releasing-clutch-pedal/#findComment-2275911 Share on other sites More sharing options...
