  • Replies 66
  • 4 weeks later...
wat r the advantages of a z32 afm? to power gain? does anyone have any comparison results ? im sitting on 306hp atm with r23 w/ rb25, apexi 300 or 400hp turbo (not sure which 1)n a pod, greddy radiator, hks fmic, oil cooler, 3" zorst w/ 2 hi flo mufflers n no cat, Twin Plate brass button Clutch,
Splitfire Coilpacks, shimmed diff
my goal is 500hp so wats next to get there ?
thanks simon :(
  • 7 months later...
Sorry to revive an old thread but my questions is still relevant so saves making a new thread.
Anyway, my car is going in to the tuners on Monday to get tuned with my new turbo, injectors and Z32 AFM but since I know how to wire the Z32 AFM into my S2 RB25det (thanks to this tutorial), I figured I could save myself some money by installig it myself..
I doubt I'll be able to solder and re-wire it outside of the tuner and getting them to push the car in, and me wiring and installing it at home before getting to the tuners means my car won't run so I can't get there lol
SO, my question is, am I able to wire some female connectors into the wires into the loom from my RB25 plug going into the ECU and some male connectors onto the other end of my wires into the plug, and then wire some male connectors onto the wires of the Z32 plug?
Essentially, it just means I can drive the car down to the tuners and when he's ready to tune, I can just unplug the old AFM and plug in the Z32 AFM.
Here's what I mean:
------[> is the male connector
}------ is the female connector connecting to the standard loom
so before I go to the tuners:
RB25 AFM--------Standard RB25 AFM plug------------[> }------------------to the ECU
When I get to the tuners:
Z32 AFM----------Z32 AFM plug ---------------[> }----------------- to the ECU
Will the connectors I put in place affect the voltages and the signals being sent to the ECU?
Edited by turbodragon
  • 4 weeks later...
probably too late now, but....this sort of intermediate connection should be OK, as the extra resistance imparted by your "quick connect" system should only be a fraction of an ohm, which wont upset the AFM output voltage. Did you end up doing it this way?
  • 4 weeks later...
Sorry for the late reply, only just seen it.
I just wired the Z32 plug into the existing AFM loom so the RB25 plug is still attached.
In other words, the one loom as 2 plugs on it, the Z32 and RB25 :thumbsup:
  • 4 weeks later...
  • 3 weeks later...
for anyone that's interested....
r34 neo install
r34 wires > z32 plug
white/blue > D
orange/blue > B
black/white > E
chassis > C
the loose wiring in the white insulation is shielding for the 2 signal wires, so do nothing with the loose wires.
  • 3 months later...
Hi everyone,
as my question is related, i will ask this here rather than start a new thread.
Is a full tune required if I fit a Z32 AFM on my stock RB25DETT NEO ???
I want to fit an Apexi power intake pod filter, and I am not sure if I should go for the stock size, or to get a Z32 and a matched filter.
I spoke with my Nismo mechanic and he said that a tune shouldn't be necessary, but i want to here what others have to say....
Does anybody know of good places in Melb to get tune and stuff done? (i'm in west suburbs)
Thanks guys
Hi everyone,
Thanks guys
complete waste of time and money. also not possible with the standard ecu, your "nismo" mechanic is wrong.
unless your maxxing your standard afm (not gonna happen on a stock car) and have an aftermarket ecu a z32 afm is gonna do more harm than good.
I suspected as much, and also read that you don't need to upgrade the AFM until you hit about 400kw, so thanx heaps for clearing it up for me guys. Much appreciated.
I am going to stick on an Apexi pod on the stock AFM and see how that goes. Unfortunately, I am one of the unlucky R34 GTT owners that is lucky to get 400km to a tank of fuel,
so I will see what kind of effect it has on my millage and decide if it's worth keeping on, as my daily drive.
400kw? No, stock AFM is good for somewhere around the 220rwkw mark. At a guess you might have been reading something about someone who completely ditched the AFM altogether and went for a MAP sensor or something.
As for your economy, there have been bucketloads of threads discussing it over the years, but particularly with a stock ECU 400km to a tank is pretty normal around town.
I want to put in a PowerFC based on everything I have read so far, but it's something I will have to save some $$$ for first, when they do pop up, they're on the pricey side... but I figure if I'm getting better millage, the thing should pay for it's self in no time
  • 11 months later...
Stupid question, but im sitting on around 200rwkw in my series 2, is it worth buying one of these? I know the stock comp will not run this but will my safc2 handle it? What do i have to do? Im not interested in a power fc at the moment...
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
