Hi all,
Can someone help me out here. I need to get my flywheel machined for my 1989 32 gtr.
Any help would be muchly appreciated!
Give me a call on 0403 477 372 or 3281 1308
cheers
Shane
Make sure you get it surface ground on a magnetic table Shane.
We could do it for you but we are a little bit out of the way.
Thanks heaps for the replys guys!
Just got off the phone with Dan, he can do it for me :D
Cheers for the heads up paul. It only needs to last 6 months or so until i get the rb26/30 in, then i'll be heading to jim for a custom clutch.
I rang Jim today at lunch but i got some other bloke, gave him my details n told him what i needed but he never called me back...
Just got off the phone with Dan, he can do it for me :)
He will probably call you tomorrow morning :/
As for the clutch....I can get you whatever clutch you want....any specs you want. Just as good as Jim Berry and probably a fraction of the cost.
See how you go though.
Not trying to start an argument. But that is a BIG BIG call.
It's all good. I know Jim Berry is one of the best. I also know Doug is just as good.
Not saying either is better than the other but I have used clutches made from both on many occasions so I know first hand. It's not like I would bag Jim out or anything, I have massive respect for him....I just prefer to use Doug as he has always looked after me and I know you are the same with Jim.
BTW...what was the big call?
Hmm, I should have phrased better. Jims advice on what to get to suit the application is probably why his are so good. He makes sure you get the right clutch for what you are using it for, then explains why. Jim and SK are the only two people I have ever come across to spend the time and have practical knowledge, to make sure you know what you are spending your money on, and why you are wasting it going down another path. For that even if I could get the EXACT same product cheaper I would still go with Jim just out of courtesy. That and does anyone else do his carbon clutches?
Doug is exactly the same. Only difference is that Doug doesn't bag out Jim but Jim bags out Nick's Clutch Service. Both are very good at what they do...the best in fact. Both are great for info.
And yes...Doug does do the Carbon clutches. I assume you are referring to the ATS style ones?
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
