hey yup 300 for the engine. no loom.
When you say complete what parts do you need with it??
bonnet & grill are dark gray
complete being complete lol, turbo/manifold/plenum/ect.. im guessing its asilver top from your R32? eccs?
6 x 550cc RX7 injectors ready for fitting to skylines. just been reco'd $400 for the set
RX7 injectors are low impedence, can be used in RB20, cannot be used in RB25.
Hope that helps.
thanks I couldnt remember. Remember all prices are neg so send me a pm.
I also have SR20DE motor in great condition for $500
SR20DE auto box $150
Series 4 rx7 bonnet $100
13B out of series 4 needs new control rings $400
RB20 bottom end (no sump) $100
S13 front seats $50pair
  • 9 months later...
