The GTR fuel tank is actually 72l. Fuel economy is very dependant on modifications, tuning and of course driving style. around 350-400 is pretty normal around town and you should get well over 500 on a purely highway cruise with minimal boost.
Hope that helps
geez thats pretty good i didnt wxpect anything like that. thought it would drink pretty steadily. i'm thinking i should seriously think about getting one now.
To be absolutely clear, the tank can _theoretically_ hold 72L, but the factory allows for about a 6L air/vapour space so the tank can never be completely filled. 65L is about the average practical fill for a GTR tank, but some will see more and some will see less.
R33's and R34's have a 65 lt tank, i believe 32's have the bigger tank.
yes r32 gtr's do have a 72 litre tank BUT you wont fit that much in them by the time vapour lock is taken into consideration
fromtime fuel warning light comes on i have only ever fit 63 litres in mine and i doubt they would allow 9 litres of emergancy fuel in the tank
From the R32 GTR factory WS manual:
Fuel tank _nominal_ capacity = 72L
Intake air capacity = 5.5L
As I said, the air capacity is an allowance for vapour, expansion, etc and is deducted from the _nominal_ capacity of the tank, which gives a theoretical max for liquid of 66.5L. Again, some will get perhaps slightly more, some less, which gazza750 has just proven and is certainly my experience.
Edited by SteveL
Just on this, but a little to the side...
Ive noticed that when my R32GTR gets a little low on fuel, mabey 1/3 of a tank, the car seems to run a little rough/chuggy on idle when cold, almost stalls, until up to temp. Buggered if i know why? Any guesses, wouldnt be to do with vapour lock/pressure would it?
Cheers.
Oh i get about 23l/100km as well Beer Baron... :unsure:
Edited by mazgtr
in my 33 gtr i get about 14-15l/100 average with normal driving, although can be a bit higher or lower depending on how i drive it... when my GF drives it it chews quite A bit less than my 4l ford (city driving), seen it as low as 11l/100km. the r is basically stock.
Edited by marchGTR
