hey everyone,
theres a strange knocking sound (like metal on metal) coming from my left hand side front suspension. it sounds like something is loose or metal on metal when i go over bumps. ive had a mechanic look at it and he said nothings loose, the wheel bearing and ball joint is fine. the mechanic said the shock may be botteming out whatever that means. its been to a suspension shop recently for a suspension check and they also said everythings good. so its been to 2 places and both say nothings loose etc, but it really dosent sound right as the noise is fairly loud and is only coming from that side. personally i think it may be the shock as the HA coilovers are pretty old but anyone elses ideas and opinions would be greatly appreciatted. thanks.
I've had this noise before and it was the exhaust hitting underneath the car. It may not be that in your case but if you haven't checked already, see how much clearance there is between the exhaust and floorpan. With the car that had it I couldn't even fit my fingers around the top. I think the engine mount might also have something to do with it, if it's worn it will allow the engine to flex up more over bumps and stuff and cause the exhaust to hit up even if there is enough of a gap. On my current car I have the opposite problem, too much of a gap there which means it hangs too low and hits the speed hump instead :ban:
If your Tein HAs have pillio ball tops, then id bet money is that they are worn...hence the bumping noise. You can tell if you have pillio ball tops asw they currently used anodised shock tops, so have a look in your engine bay and see if there is an anodised alloy plate visible through where the shock bolts to the body
yeah its defn the upper pillowball mounts..
im in the same problem..
guess what.. they are not cheap!! ... i am thinking about getting new shocks alltogether cause of it..
man mine makes a loud ass noise.. embarrassed to drive ppl in it :) ..
maybe we should go get new stuff or front upperball mounts together,, get a small group buy deal :thumbsup:
cheers,
JD
JD Give www.shockreco.com.au a call and see what they can do for you.
They are in queensland but they were the only ones in australia that i and many workshops know of that do recodition,id say all brands of shockies,back to their stock specifycations.
I sent them through australia post to Queensland,as well giving them the return p/h monies up front so no dilemmas in sending it back asap.
Worth a try.The price i found was reasonable also.
anyone know a price of the pillow joints? my recently purchased Tein HR shocks are knocking pretty bad. I now know why he was selling them!! Got someone to drive whilst i was in the boot and could feel them knocking.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
