I have a problem with the engine water going to over 100 degrees c. when driving at low speeds.
The engine has now been rebuilt and i checked the water pump, changed the termostat to a sard 68c. and changed to a koyo aluminium radiator.
But I still have the same problems....
Can anyone give me some advice on what else to look for?
What is the normal watertemp on a rb26?
Thanks in advance!
Edited by c-west norway
https://www.sau.com.au/forums/topic/116570-rb26-vater-temp-problem/
Make sure there isnt any air in the system, and that you are using the right mix of coolant/water???
Driving my one around town i get it up to 84 degrees, but spirited driving can get it up quite high of course
What are you using to monitor the temps with?, and what model of car do you have, your info says an S13, its possible if you have done a engine conversion, and have used the rb26 dash temp sender, instead of the one meant for your model of car, it's reading different, just went through this myself, at 90 degree's, the needle in my 33 with a 26 sender was off the top of the dial, witht he 25 sender its down at mid way where it should be..
its a r33 gtr engine in a s13.
Right now I am using the comander on my apexi pfc to read the watertemp.
The needle in the dash only moves a few millimeters when the engine is hot.
Can I change the rb sender with my original s13 sender to get it working?
Where are the sender located on the enine?
Yes, you can use the S13 gauge sender. Its pretty innacurate though. Doesn't start reading to 50 + degrees and doesn't actually read over halfway untill around 100 to 105 degrees. The engine thermistor that the Power FC is reading is a much more accurate way of reading the temperature. You can screw the CA sender in the same place that the RB25 one fits. I've ditched my standard gauge completely now and use a Defi HUD to monitor temperatures.
What sort of radiator fan, intercooler and front bumper have you got and is it a european 200SX i.e hatchback RS13 ?
I've found the RS13 does need a lot more thought when you fit an RB, particuarly one with two turbos as it has much less grille area than a Skyline. Even with a aluminium Koyo, efficient shrouding and the biggest fan you can get on it cooling is very marginal when stationary, slow (sub 40mph) and also at sustained 85mph + speeds.
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
