QRI05E Posted May 5, 2006 Share Posted May 5, 2006 (edited) Hey guys, as we all know and read it 100 times before in this forum that many SII RB25DET's suffer from spluttering/misfire at 5000RPM under heavy acceleration. However, since every car will vary in cause of this misfire, here are the symptoms of my car... 1. Very slight stuttering/poping on idle (when warm) but not noticable at all. 2. Distinctive spluttering at 5000RPM at heavy load in 2nd, 3rd and 4th gear (not in 1st). 3. Occasional pop/backfire from exhaust when changing gears at ~ 4500RPM (due to cam timming?). As for the slight stuttering/poping on idle, im going to give my AFM a clean with contact cleaner due to oil from K&N and check to make sure there are no dry/cracked solder joints. I was also going to remove my coil packs and give the electrode a clean with light sanding and check for any cracks. Then i was going to check my plugs to see if any are fouled up and make sure there gapped at 0.8 NOTE: about a year ago i got the coil packs repaced with secondhand ones... NGK Platinums gapped at 0.8 where put in... this soldved the problem up untill now... since then i have also put a split dump and 3" exhaust and Turbotech at 9psi... Am i on the right track??? any other advice??? and YES i have used the search button Kind Regards, Sarkis Edited May 5, 2006 by QRI05E Link to comment https://www.sau.com.au/forums/topic/116573-sii-rb25det-coil-packs-plugs-afm-tipsadvice-please/ Share on other sites More sharing options...
RANDY Posted May 6, 2006 Share Posted May 6, 2006 Check the packs for hairline cracks or signs of arcing. Also search and read a big thread about fixing this stutter and high-rpm issue. Seems that 90% that tried the coilpack fix have walked away happy. Link to comment https://www.sau.com.au/forums/topic/116573-sii-rb25det-coil-packs-plugs-afm-tipsadvice-please/#findComment-2144686 Share on other sites More sharing options...
QRI05E Posted May 6, 2006 Author Share Posted May 6, 2006 Thanks for the advise, ill do a search... you know the link to the post?? you think im waisting my time cleaning the AFM??? Cheers Link to comment https://www.sau.com.au/forums/topic/116573-sii-rb25det-coil-packs-plugs-afm-tipsadvice-please/#findComment-2144820 Share on other sites More sharing options...
