Hey guys, as we all know and read it 100 times before in this forum that many SII RB25DET's suffer from spluttering/misfire at 5000RPM under heavy acceleration. However, since every car will vary in cause of this misfire, here are the symptoms of my car...
1. Very slight stuttering/poping on idle (when warm) but not noticable at all.
2. Distinctive spluttering at 5000RPM at heavy load in 2nd, 3rd and 4th gear (not in 1st).
3. Occasional pop/backfire from exhaust when changing gears at ~ 4500RPM (due to cam timming?).
As for the slight stuttering/poping on idle, im going to give my AFM a clean with contact cleaner due to oil from K&N and check to make sure there are no dry/cracked solder joints.
I was also going to remove my coil packs and give the electrode a clean with light sanding and check for any cracks.
Then i was going to check my plugs to see if any are fouled up and make sure there gapped at 0.8
NOTE: about a year ago i got the coil packs repaced with secondhand ones... NGK Platinums gapped at 0.8 where put in... this soldved the problem up untill now... since then i have also put a split dump and 3" exhaust and Turbotech at 9psi...
Am i on the right track??? any other advice??? and YES i have used the search button :/
Kind Regards,
Sarkis
Edited by QRI05E
Check the packs for hairline cracks or signs of arcing. Also search and read a big thread about fixing this stutter and high-rpm issue. Seems that 90% that tried the coilpack fix have walked away happy.
