hey all.
im fairly new to the skyline... infact japanese import scene in general. just recently purchased a 1995 nissan skyline R33 GTS-T. it only had 51,000km on the clock.
ok before you laugh and say what an idiot. a 1995 skyline with so few k's? i thought the exact same thing. i did do alot of umming and arrring before i bought this car. i got it fully checked out, i looked over it myself and test drove it. i was astonished, the interior and exterior were immaculate. not a scratch or dent in the body anywhere. no marks or tears or anything in the interior, everything worked as it should. so i was beginning to think it can't be too far away from what's on the clock, even if it is wound back alittle out of japan.
then i found this. 100,000km sticker right smack bang on top of the engine. i did look under the bonnet. but i think i looked everywhere except for the easiest place to look, top of the engine haha.
the sticker is completely in japanese and i can't read it... only thing i can read is the 100,000km part. i have bin told that the sticker means its gone through its 100,000km service. then ive bin told the sticker just says the timing belt needs to be changed at 100,000km. before i bought the car, the guy changed the timing belt for me anyway.
so my question is, does anyone know wat the sticker means? do they have it on their cars? and if so, is there anyway to tell really how far it has gone past 100,000km? car has no log books etc which dosent surprise me.
thanks in advance,
brendan
https://www.sau.com.au/forums/topic/116606-are-my-worst-fears-confirmed/
I've heard the same as you, could be timing belt to be changed at 100,000 or it has had it chnaged at 100,000..
A car with 100,000ks on it can still be in very good condition, average person may do 20,000k/y, = 5 years of driving, go check out a 5 year old car, there will be lots out there that look immaculate...
Either way don't stress to much, the main thing is the condition of it, not the number that the odo says..
Speaking as a mechanic in the jap import industry, that sticker is there from factory to make it clear that the belt is to be changed. The japanese are going back to chain driven cams, so this may give them a proper reminder.
I know on the GTR engines there is also a tag on the crank angle sensor that must be torn to adjust the timing. When you by a timing belt from Nissan you get a sticker to put on the engine, which you write the next belt change on, and also the sticker to go over the crank angle sensor once the timing is set.
In my experiance (8 years in automotive industry) the actual kilometers a vehicle has travelled isn't all that useful in determining if the car is a decent piece of kit or a rooted out piece of junk. I've seen cars with 250,000 kms look like new. and I've seen cars with 50,000 kms that are good only as scrap.
So take your time and check wearing parts like suspension and steering, brakes, and condition of things like hoses etc. you'll get a better indication of that rather than the speedo. My vl turbo had done over 200,000 kms when i bought it, now its nearly done 350,000 and the main issue ive had is an alternator.
Ok my R32 has no sticker on the timing cover, does this mean that the timing belt has been done??? I actually think someone may have taken it off or came off? Is there any other way of telling if the timing belt has been done recently??
ahh ok thats good then. thanks guys
Exactly the same situation mate, bought mine at 73K on the clock, looked immaculate everywhere, but when i reached 100K the odo stuck and also doesn't line up quite properly, which is a sure sign its been wound back. Like ferni says, worry about the actual condition more. I'm on 140K at the moment and haven't had any major issues that weren't caused by myself or someone else.
timing belt change is expensive, but new engine is even more expensive :D
For the record, on a R32 GT-R its about $400 if the water pump needs replacing (and possibly more if any of the tensioners/guides are worn).
My car is finally getting its belt changed this coming friday; I'll be able to sleep that little bit easier :P
Yeh I recently imported my 1990 r32GTST its in great condition,but its done 115ks and Im getting my timing belt done next month as my sticker has faded and cant make out when timing belt was done..
Just to be on the safe side, Id rather pay the money.. as dont want my car to die :P
well the guy at the used car yard changed the timing belt for me anyway, to be on the safe side. so that's no worries. just was more concerned with the condition of the rest of the engine... ie how good a nick the turbo would be in.
i have a sticker on top of my engine (r33) and it had 68, XXX km on it. Would this mean they changed the timing belt at those km's?
I bought my car when it had 77, XXX km on it a few years back. It's on 103, XXX now and when i came up for the 100 000km service my mechanic said the timing belt had already been changed. So i assume that this is what the sticker indicated...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
