Sold Sold!
to be honest mate i couldnt really tell ya cause i dont drive around to drift or anything much..
the car has been serviced by my uncle who is a mechanic so it has been looked after well
Do you find it hard to drive on the street? How long has the diff been locked for? Is it on the stock axle?
Sorry for all the questons dude im just trying to sus it out
suprisingly there is not much difference to driving with a locker
like when you go around a sharpish corner you get a little skiddish/clunk but there is nothing majorly different to a normal axle
its been locked since i got it..im assuming its on the original axle
nah the questions are fine..id be doing the same thing
the only other things with the car is the horn has cut out recently..i think its a simple wiring thing but ive been so busy with work i havent had the time to look at it
and with the coil overs being fair low sometimes the springs give a little thump but its due to the high of it.. easily fixed by raising the adjustables..
so thats about it with the car
i need to sell soonish as you could understand due to the rego coming up soon
so have a think and let me know what your thinking..cheers mate
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
