I have for sale a few parts that need to go to pay for new turbo.
RB26 Clear Cam gear cover (genuine Trust) Brand new!! $150 ---Sold---
RB Genuine Tomei Cam Gears, used a little, but in good condition $380
Custom RB30 Twin throttle plenum. I made it for someone who was going to go for highish power N/A RB30 but decided to go twin cam head instead. It has had a lot of port and sanding work to make the air flow as linear and undisturbed as possible. Can also be used for turbo application and also uses standard AAC Valve. $500
I have a Monza Blow off valve thats on some 3" pipe, works fine, have gone to a different setup and needed a plumback. $100
T04e Garrett turbo, off a running rotary that put out nearly 350rwhp. has a .7 a/r compressor housing and 57mm wheel. turbine is a 1.32 a/r with 'p' trim wheel and is T4 flanged.
The bearings are a little worn and advised to get them done.
I was going to use the turbo as a build up to a T66 wheel and the like but have toned down my power levels and going smaller turbo. turbo is also external gated. $400
I also have a RB30 cam gear cover that has had a circle cut for an adjustable cam gear and then powder coated silver. Its a little dirty, but still good $50
Any questions or want any more pics, please PM me or phone 0412957329
Robb
Edited by Dj laBBy
https://www.sau.com.au/forums/topic/116615-parts-clear-out/
It sounds like a blow off valve, Tssshh
If you can imagine, you take off, comes on boost Rrrrrrrmmm, then change gears and Tssssshhh!!
heheh sorry mate :P
Edited by Dj laBBy
https://www.sau.com.au/forums/topic/116615-parts-clear-out/#findComment-2158704
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
